http://www.zaphaudio.com/archives.html
See comments on P17/D25 above.
http://www.geocities.com/woove99/Spkrbldg/Usher_2way/Usher_2way.htm
Should suit the design brief.
Do not build a 3-way unless you are a c/o design expert.
The PMC midrange http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-550
Gets a very bad press generally, perhaps because the design is so old.
🙂/sreten.
🙂/sreten.
As far as the resolution of the illustration allows, a quick calculating tells that the wall thickness of the cabinets should be approximately 18 mm's - this is a standard thickness for MDF.
