Hi all!
Andrea and me and Pavel Pogodin have new design dac with input Ct7302,
Please see some . Thanks
STAR Pure DSD DAC
1 x Star Pure DSD DAC module
1 x Controller LCD module
1 x XLR and RCA output module
1 x Silver remote
This not include Amanero USB module (you can buy directly) and this not include 6.5V 20VA transformer.
INTRODUCTION
The high resolution PCM at 96-192KHz 24bit offer the possibility to have a good quality digital signal exceeding the big limits of the CD.
The DSD is very different from PCM, using a sampling frequency 64 times higher than that of a standard Compact Disc, offers a frequency response of up to 100 kHz and a dynamic range of up to 120 dB across the entire audible range.
The DSD on paper should be better than hi-resolution pcm like the 192KHz 24bit because the two conversions (from and to the analog) are more simple (see this article from Korg website) but the AES Convention Paper 6086 and AES Convention Paper 5395, seems to contradict this.
The DSD signal can be directly used to reconstruct the original analog signal with a simple RC filter but with this method we get many digital noise also using a good digital and analog filters so forget this method.
I have lost many time and money to test these solution, using different USB to DSD interfaces, I2S isolators and D-type flip-flop.
The little Lampizator and RT audiodesign companies has succeeded to reduce the noise and produce a DSD DAC with this method but with some limits.
This project here exposed has another approach, it is based on the DSC1 that is an Open Hardware, "discrete" delta-sigma D/A-converter developped by Signalyst, the DSC1 is able to convert the DSD signal to analog without noise and without a DAC chip.
The DSC converters does not work with a PCM signal so it is necesary convert the PCM to DSD on the fly during playing so it is necessary to use computers with adequate performance.
In this project we have used the CT7302PL single chip dual channel audio digital to digital bridge with a sample rate converter to convert PCM signals to DSD.
HARDWARE
The core of this design is the CT7302PL with the following specifications:
SPDIF support up to 768 KHz/32bits mode
I2S support up to 768 KHz/32bits mode
DSD support 1x/2x/4x/8xmode
DoP support 1x/2x/4x mode,throughI2S
DoP support 1x/2x/4xmode, through SPDIF
PCM SRC / ASRC fully support 32 KHz~ 768 KHz.
PCM / DSD / DoP to PCM / DSD / DoP converter with SRC / ASRC
Crystal reference clock / MCLK / DoP / Mute status output
Auto De-emphasis32KHz/44.1KHz/48KHz.
Auto detecting PCM / DoPformat.
Auto detecting I2S / DSD interface.
Volume control with fading in/out.(+18dB ~ -110dB step 1/32 dB)
SRC / ASRC 32 bits dynamicrange(192dB), THD+N (-174dB).
After the CT7302PL chip there is the DSC in the differential version designed by Pavel Pogodin with the output transformers to filter and to convert the output in un-balanced and balanced signal.
The 74AHCT595 are high-speed Si-gate CMOS devices used for the serial-to-parallel data conversion.
This module use a mute circuit to eliminate any click in the transition from one track to another using the TS5A3167 (SPDT) single-pole double-throw analogswitch .
This module need a AC power supply in the range 6.5V - 7V and it can power the Amanero USB module with a dedicated 3.3V.
On Amanero module to exclude the USB power supply and use an external 3.3V is necessary cut a wire or remove on-board regulator.
The USB interface used is the Amanero with the normal firmware to support Native DSD.
The Controller module included in the kit use the 16F877 chip, a 20MHz Enhanced 8K Flash Microcontrollers.
It drive a 4 x20 characters LCD and it is connected with the I2C bus to the CT7302PL.
A separeted power transformer is used to manage the standby function.
OUTPUT TRANSFORMERS
The output transformers are necessary to mix the differential signals coming from the 74AHCT595 in phase and out phase.
These are also used to give un-balanced and balanced output signal, the module integrate a relay to switch the ground connection.
The models has been selected by Pavel Pogodin after many test and also I have compared these with other models with much higher cost always preferring these.
These have a turn ratio of 2:1+1, made with a permalloy core with a thickness of 0.16mm and an inductance about 340H.
The declared frequency response is 10Hz - 195 KHz at -0.2dB for the yellow and 20Hz - 80 KHz at -0.2dB for the black type
Yellow type has more "air" and black are probably more balanced but it all depends very much on the record or even his mood.
Taobao
AliExpress
Alixpress type 2
REMOTE
SOFTWARE
This hardware is compatible with any PCM and DSD signal so to play music you can use any audio player.
Here follows some player in order of sound performances.
HQPlayer by Signalyst available for Windows, Mac OS and Linux, there is a Server and a Desktop version at a cost of 145,18 euro
Daphile Audiophile Music Server for x86 hardware, it is free but it need a dedicated hardware
JRiver Media Center available for Windows and Mac OS at a cost of $49.98
Foobar2000 freeware
In same case it is necessary increase the output level so use in the setting menu the V+ and -V buttons to set +6dB. +12dB or +18dB, I suggest a max of +6dB because otherwise the distortion can increase.
There is also a function to set an amplification of +6dB for DSD tracks because some player give a lower level for these.
All the settings can be saved in the EEPROM so these will be set at the next power on (press mute button on Setting menu).
MEASUREMENTS
Output at 0dB near to 1.5Vrms.
REVIEWS
STAR DSC took first place in the contest organized by the forum Vnav
Here is the result of a test in October 2019 with a friend of mine with a lot of experience in recording and playing audio.
Yesterday evening the first serious listening test about the new dsc module with CT7302 vs NAA (Network Audio Adapter) DSC module.
The quality of the last DSC with CT7302 is very high, the same details and the same sound stage of the NAA DSC module.
The NAA DSC module with the HQplayer filters is a little bit more softer but it is not easy define if it is more or less near to the real sound.
Using the CT7302 with jRiver the sound is very natural and analog.
PHOTOS
STAR Pure DSD DAC
1 x Silver remote
INTRODUCTION
HARDWARE
OUTPUT TRANSFORMERS
Taobao
AliExpress
Alixpress type 2
REMOTE
SOFTWARE
Foobar2000 freeware
MEASUREMENTS
REVIEWS
PHOTOS
Some image I make it, please see it now.
Thank you very much!!
Have you made any comparisons between the CT7302PL sample rate conversion and that available with HQ Player 4?
you can see test by Andrea:
STAR Pure DSD DAC
Could this be used in a multichannel setup with DSC2 ?
I was wondering if a x-mos based multichannel USB to I2S card was used and 2 channels were routed to one CT7302PL and 2 other channels routed to another CT7302PL (so the timing were accurate). The dac here is for a subwoofer and does not need to be a full DSC2. Could be a simpler version of a NO-DAC maybe? I want to make use of a digital X--over so I need 4 channel output. This cannot be done with Amanero USB to DSD direct as this is only 2 channel.
Nice!
So what are the plans to make this available to us DIY'ers?
ok, so i soon open GR !
thanks
Very nice Quanghao. I would like to buy a kit at the end of Npvember so please tell me the price for the kit and what the kit consists of.
yes, soon i open gr, thanks
That sounds wonderful.. I stlll wonder if I can use one complete STAR Pure DAC and one CT7302PL with my existing DSC2 and the timing then will be fine?The STAR Pure DSD DAC can be used in a multichannel setup using 2 modules but I cannot be sure of timing if you use a different DAC for the subwoofer.
I can write a custom firmware to control 2 DSC module with one controller.
Yes . The sound is best now with ct7302.
But the code is not easy for setup! Many problem !
Thank . So we try to test for you now.
Come to think about the timing. It is not an issue at all after all. I use Audiolense to do the x-over and it can handle the timing, no matter if it comes from different delays in DAC´s or from different distances to the speakers. Actually I think I could use a USB to I2S multichannel board and CT7302-DSC2 for the main speakers and a normal DAC for the subs...The STAR Pure DSD DAC can be used in a multichannel setup using 2 modules but I cannot be sure of timing if you use a different DAC for the subwoofer.
Hmmm...I just finished building my DSC 2.6 and now you guys come up with something better....which even solves the Hardcore PC machine needed for HQplayer...some questions:
- Will there be a pcb version, ideally where the tough components like Microchips are pre installed, but where one can put his own flipflops and resistors (from my 2.6 project, where i got the original old Philips stuff Pavel suggested and the tant. resistor for 130 Euro in place) ...or will this all be open source again ?
- are you guys considering a "2.6" version ? So either where you could integrate the PCM to DSD converter in a regular 2.6 or using your board and have a pcb which can take the BBB on board like Pavel did it in 2.6 ?
- Looking for the GB, will be onboard for sure...i like the enclosure...will you offer this as an option ?
My question is, will there be a PCB or kit with just I2S in and DSD out, so one can use whatever generation of the DCS one have?
ok, i try do it for the next time! waite it plese!
thanks
quanghao
flipflops, with my testing and Andrea's test, THD increased, making the noise even more,
Good resistors are good options, I am using Vishat MMA2004 for all.
I will try to do this next time, please wait
Chassis is large including: there are 2 colors:
black and silver color, material: aluminum 8-10mm thick.
Dimensions: Width: 445 mm, height 80mm, depth 380mm, weight; 5 kg.
Price: 200USD + shipping!
- silver control.
thank you
Great idea Koldby .I have a dsc1 which I love the sound of but an input board based on this design would save me a lot of money.
- Digital Line Level
- STAR Pure DSD DAC-Signalyst New
