In my first job after I moved to Cali (early 80s) I worked for a firm that made 2-way radio test gear. While there, I encountered a curious bit of hardware meant for providing a central star grounding point on a chassis, It consisted of a little turret that you screwed down to the chassis. It had on top a circular hub pierced all around with holes, so you could insert all the ground wires you wished to terminate at a given point. My colleagues used to call them "ground wheels", but if you search by that term or other obvious variants, you get everything but that. Does anyone know the exact name for this part? Engineering is like magic in some ways - if you don't invoke the demon by his exact name, he won't come.
uuuummmm... I am pretty sure that is known as the small round metal thingie with holes in it?
Actually, I've never laid eyes on one that is commercially made.
Looking forward to the answer! 😀
_-_-
_-_-
In absolute desperation I may call local distributor Olander Fasteners and ask them. They are the purveyors of all sorts of weird fastener-related kit to Silicon Valley, and they've been at it since God/dog was a boy...
Have you looked at electrical supply houses or similar??
I'm thinking for no good reason that these originated with sign lighting work, or theater type wiring... but I have no reason to know why my brain thinks that.
I'd expect someone else might know... also try this question on an antique radio forum?
_-_-bear
_-_-bear
We just had a thread about these on some forum I frequent, forget where. Within the last few months or so.
There are the rings - like a wide washer with holes around it. Then there are the ones that look like six regular solder lugs fanned around a circle, but is in reality one six-lobed lug with center hole.
They may have some for high current work like signage, but the ones I have in mind are small sizes for use in things like amplifiers or other consumer goods.
Is this is what your are looking? 8 Point power Distribution Block
Link:Power Distribution Blocks | WiringProducts.com
Same principle, but way too big for my purposes. The part in question has a small hollow shaft with a disc on top that's pierced around its periphery to accept wires from all around. The hollow shaft allows one to stack a few if you have an utterly insane star grounding situation. The actual part is about as big around as a thumbnail. I may have one or two stashed away in my junk somewhere, but you know how that goes....
At any rate, I'll probably make do for the time being with a threaded spacer, a couple of star washers, and a bit of copper clad. Not as elegant, but it'll get the job done and allow me to complete a project siting in the queue.
Or throw several regular old solder lugs under the same mounting screw and fan them out at different angles.
That's kinda ugly/obvious - the ground wheel (or surrogate) is much nicer. I wouldn't trouble myself overmuch, bit this time I have a fair number of ground wires to convey to the same location.
A copper pipe cap, available at any hardware store, works pretty good for me. I trust soldered connections better than mechanically tightened ones. Just be sure you've either tinned the cap and/or have plenty of heat so the solder will reliably flow onto the thicker copper. I either drill holes into the side or use a thin saw blade to cut slots to insert wires.
You can make one using a copper laminate and cut it by using a hole saw and then drill the holes.
Yeah, I can make most anything - the point was to find the real deal. Bear - the thing in the picture was exactly the grounding hub I'm looking for.
- Design & Build
- Parts
- Star Grounding Hub Connector
