Standard conditions for max plate dissipation vs plate loads
Just a few observation to keep in mind... Idle plate dissipation may be really hot in some amps, however, when running signal the plate dissipation can be much lower...
Thanks cerrem,
I know better musical instrument that hi-fi amps, and indeed EL84s are the most abused usually (higher plate and screen voltages, higher idle power, etc...). This is not my case, as I usually stay around 60 to 70% idle current for AB fixed bias, and 80 t 90% for cathode biased "class A".
operating voltages are totally different than idle...therefore the average plate dissipation will be much lower than idel..also taking into account the load-line path...is not linear ...elliptical ..
Totally agree, maximum plate dissipation is not at idle nor at full power, as it is expected by the intersection of the load-(quasi)line and the "W = V x I = const" ellipse. On top of that, guitar amps often intersecs twice the maximum plate dissipation, just because the avarage is within specs (almost half of the time the tube is off).
