SSE first build, caps and other questions.
Finally checking out my amp. Using Ty's checkout regimen I obtained figures that left me questioning. V10 pin 3 was 9.886 ohms, pin 7 was 74.6, and pin 8 was 9.86. The power tube sockets both pin 5s were230.3, both pins 1 and 8 were 10.2. Is all okay and go ahead plug 're in, or does something warrant looking at? Thank you.
..... V10 pin 3 was 9.886 ohms, .... and pin 8 was 9.86. ....
May or may not be a problem. Cathodes of the dual triode. There is an electrolytic capacitor bypassing the resistor. They have to be allowed to charge. It would read low while it is charging. After they have charged, it should be 220 ohms.
pin 7 was 74.6,
Grid of the triode. Should be 220K. Do you have a volume control installed?
The power tube sockets both pin 5s were230.3, ....
Control grids of the power tubes. Do you by chance have an autoranging voltmeter? 220K is normal. 220 is off by a factor of 1000.
..... both pins 1 and 8 were 10.2.
May or may not be a problem. Cathodes of the power tubes. There is an electrolytic capacitor bypassing the cathode resistors. They have to be allowed to charge. It would read low while it is charging. After they have charged, it should be whatever your cathode resistance is.
The pin 7 isn't right. I would re measure the others letting those caps charge, and make sure you have 220K resistors on the grids of the power tubes, and not 220 ohm resistors. You may have misread the color bands and swapped some resistors - it's easy to do, and we've all done it at one time or another.
Win W5JAG
We all do this as a learning experience right. Now I see the K on my meter. All the readings I used ground at T1. I do have an Alps blue velvet volume control. Aside from V10 pin 7 now reading 9.86 all other readings are the same. I left the meter leads on two to three minutes for caps to charge. Don't know if this makes a difference- PT is Allied 6k7vg, 0PTs are Edcor GSXE 15 8 5s, C11 and21 are Aurucaps .22uf /600 v, R 17 and 27 are Vishay 560 ohm 5w. Thank you w5jag!
The readings of pin 2 and 7 of the 12at7 will be lower with the volume pot connected but should still read fairly high.
They should also read the same - mine both read 40K with the volume up full.
What does your pin 2 read?
I think you have a short at the volume pot or it may be connected wrongly.
Maybe you should wire it up without the volume pot and check you readings like that.
I removed the board from test bed. Just pc board by its self. The current readings are: V2 pin 8 157.1k ohms, V10 pin 1 162+k ohms, pin 2 and 7 230.7 k ohms, pins 3 and 7 10.2 K ohms, V11 and 21 pins 1 and 8 10.2 k ohms, pins 5 230.7 k ohms. I haven't checked the volume control for shorts yet. I will. Any suggestions of what to check? Thank you for the help.
Tube Fit
Ahhhh. Went on vacation.
When I got back I checked grounds for the pcb. Ureka! The input I'm using is a 3.5 mm plug. It has four tabs, two channels, common and ground. I wrongly thought the ground would also work for pcb. Added connection. Now my checkout readings are right in line.
Proceeding to power checks. My probes won't fit in V10 socket holes- too big. I tried my tube and it is extremely tight. Like tube is over an eighth of an inch off socket. Is that okay?
( In the mean time I will use micro alligator clips on V10)
Help
On to power testing.
I am using three meters. One old (1990s) Radioshackauto-ranging meter with a 400 vac limit.
One new GE 2524 digital 500vac, and one new Allison EM380 digital 600vac meter. Both from Walmart.
Preamp tube pins 4 and 5, and power tube pins 2 read 2.3 vac on the auto ranging meter, and 76.5 on the 200 scale from both other meters.?
On rectifier socket pins 4 and 6 both new meters read 419 on the high scale. Okay.
Rectifier pin 2 reads 1247 on the 500 meter and 13?? on the other.????
My wife was sautéing something in the kitchen- I thought it was the pcb. Maybe I could have. Everything Looks okay.
Meter?
