Spot the mistake on this RIAA pre amp
4562?
Newer chips exist...but the 20 uV/sec slew rate is right at the limit, higher will give distortion.
Feed back from negative rail of first stage too, maybe that is the problem.
Rail voltages not mentioned, that has a big affect on performance, I would like at least +/- 8 or up...rated as +/- 2.5 to +/- 17, so I would run it towards the higher side for better response.
With low supply volts it will sound muddy.
Try changing input and output impedances too.
I have used TL072 in a phono pre-amp, it was clean enough for The Eagles on vinyl.
Clear on the famous guitar duet about 4:23 into the song 'Hotel California', my version is 6:30 long....
Amp was a small Philips, 2030 and 1875 on either channel, Sony speakers.
This is some test, or you really have a problem?
Thanks....yes I have a real problem with it....low gain and insufficient high frequency response (dull)
Using a voltage controlled source together with a laplace transform to create the inverse RIAA source, the response is pretty well flat and would produce an overall output voltage of 270mv from a 5mV / 1kHz nominal moving magnet transducer. That's what would have been the norm back when the design was originally published.
Many thanks Mooly. I'd love to see your attached file but cannot open the .asc file even after downloading a few apps that should work
The first stage will clip first at the high frequencies due to the "rising with frequency" output from the MM transducer. Raising the gain of the first stage will reduce the overload margin at those higher frequencies. After the first stage, the RIAA network will attenuate all frequencies but with more attenuation at these higher frequencies and provide a level response before the signal is applied to the second stage and also result in an evenly distributed overload margin for the second stage.
Reactions: sonicles
The program to use for viewing and working with the .asc file is LTSPICE. It's widely regarded and also free to download and use.
  • RIAA Preamp2.asc
    RIAA Preamp2.asc
Are you actually using the LM4562? A quick perusal of Self's 'Small signal design' will show that the current noise of the 4562 makes it just about the worst choice possible for MM stage. In this application, it's even noisier than the 5532, let alone 5534 - which is vastly quieter.
In my own experiments, I've found that higher source Z doesn't only exacerbate the 4562's popcorn noise issue (still here, even in batches purchased in 2022), but even affects its stability. When I first got samples of the 4562 around 2008/9, I seem to remember that trying it in a phono stage created a cyclic instability, that was solved by swapping it for an OPA2134 (same slew rate if I recall).
I suspect you could pick a randon dual OA and it'd be better than the 4562 for MM phono input noise-wise. I'm quite staggered that Ti would've suggested it in the apps data. It really doesn't like those kind of source Zs. With low source Z (and careful vetting, for the popcorn problem...) it's stellar, and can give figures that will challenge all AAs bar top-of-range AP / R+S.
First put bigger caps, 22 uF, and +/- 12V rails, see what happens.
Then change out the chip, put a socket, and do the op amp rolling bit till you are satisfied.
TL072 was chosen for my build because it is cheap, easy to find, and has enough slew rate (above 8 is enough for audio).
Proper techniques of termination, grounding, shielding and so on also matter, I got RCA cables without shield continuity, had to exchange them, they were the noise source.
It's from a National Semi application note before NSM was purchased by TI.
Indeed. When Nat Semi's team still had the great Mr Pease at the helm, which makes its inclusion even more incredulous! I totally get why they would've wanted to maximise its market potential (they even suggested a tape head amp), but considering it's easily outperformed by an IC that came about 30 years earlier (5534), it does seem odd to me that it'd be included without raising a few eyebrows.
it is often specmanship, and TI is good at hiding the not so good values. especially when it comes to noise with HighZ capacitive sources like photodiodes, the common mode parasitic capacitance is a big contributor. I ended up better using a non-RRI from analog even though the specs sounded better of the competitor.
The NJM4562 is not the same IC! But you can bet that most of them give the same specs, unlike the LM4562, where around 30-40% have various degrees of burst noise!
Bassreflex makes a good point re: Ti massaging specs. Several conversations broke out at Ti's groups re: burst noise. They said nothing and locked the threads. It was then noticed that the noise specs were revised to show noise spec BW above 400Hz!
