26 mH with a minimum resistance of 800 ohms impedance will doubling approximately 5 kHz.
That very early for full-range speakers:
F = (159,2 x 800 ohms)/26 mH = 4,9 kHz
Inductance very uncomfortable. It varies with frequency, though non-linearly.
Therefore, use a different, very convenient parameter. Which is easy to measure and standardize. Its easy to see in the impedance curve. Which usually results in a single graph of the amplitude frequency response.
This is the frequency doubling of the minimum impedance: F2z. This point roughly corresponds to the double maximum possible reduction of the current at a constant level of the input voltage through the speaker.
Minimum impedance in these speakers typically at frequencies of 150-300 Hz.
Has set for itself for optimum resonance in 8" full-range speakers.
This 45-60 Hz.
Then, at low frequencies there is no problem. And sensitivity is non reduced.
Parameter F2z full-range speakers with a wide range of often 15-27 kHz.
Very well when more than 40 kHz.
This area of work is very good tweeters.
This 45-60 Hz.
Thank You, Svjatoslav.
So I can conclude - my Philips AD3800AM speakers have no real bass and no real treble. 🙂
They do a very fine midrange, though.
Best
Ole, Copenhagen
Best
Ole, Copenhagen
otc;3946119 ...They do a very fine midrange... [/QUOTE said:Absolutely no doubt about that. )))
That the quality of the midrange is beyond praise.
Direct access, without a transformer, it is something that is necessary for this.
Jazz should sound without problems.
Diagram complex impedance with frequency TFR8-2000, №14
Clearly seen that the inductance of the coil (at 1 kHz) does not matter much.
150 Hz / 20 kHz - almost a straight slanted line!
Z very complicated dependence on frequency.
Expressed in dB: 0 dB = 2 kOhm.
Full-range speaker, 2 kOhm nominal.
Couple TFR8-1000, №22, №23.
This pair experienced. More than the usual reduced inductance. As a result, the shifted F2z to higher 5-10 kHz range. The mechanical quality factor is reduced.
Deviation of the impedance in the band 80-20000 Hz at №22 was 1.44; at №23 - 1,51 times.
Thiele-Small parameters: DC resistance, Re; resonance frequency, Fs, Hz; Q-- mechanical, Qa; electric, Qe; complete, Qt; equivalent volume Vas. Frequency doubling of the minimum impedance F2z, kHz.
........Re, Ом;....Fs, Гц;.....Qa;.......Qe;.....Qt....Vas, л,....F2z, кГц.
№22...770.........51,8......5,20.....1,60...1,20....-...........53
№23...760.........50,5......4,96.....1,53...1,17....-...........48
There are measurement results speakers with a nominal 1000 and 2000 ohms, in the anechoic chamber, strictly according to the classical method.
Deviation in the range above 100 Hz is not more than 0.5 dB.
Parameters Thiele-Small:
Z=1000:
Re - 771om
Fs - 53.17Hz
Vas- 48.3L
Mms- 13.21grm
Qms- 5.5
Qes- 1.726
Z=2000:
Re - 1483 om
Fs - 54.65hz
vas- 44.8
Mms- 13.44 grm
Qms- 7.713
Qes- 0.5358
In attachments, frequency response speakers with a nominal 2000 ohms, impedance, frequency response apmlitudno and THD speakers with a nominal 1000 ohms.
40-22000 Hz from a single 8"- not bad.
"In the regiment" 22,000 Hz and a 2000-ohm speakers!
Confirmed peculiar characteristic of the complex impedance. Very small increase with frequency, instead of the classic quadratic curve - almost straight sloping line.
Z=1000:
Re - 771om
Fs - 53.17Hz
Vas- 48.3L
Mms- 13.21grm
Qms- 5.5
Qes- 1.726
Z=2000:
Re - 1483 om
Fs - 54.65hz
vas- 44.8
Mms- 13.44 grm
Qms- 7.713
Qes- 0.5358
Measurements alternative: "... do not claim to infallibility metrology, and can not be used for comparison with the results of other similar tests ..."
Shows the spectrum of harmonics. Range is measured in a wider lane:
TFR8-800, №24, №25.
........Re, Оhm;....Fs, Hz;....Qa;.....Qe;.....Qt....Vas, l.
№24...596.........40,1.....11,0....0,54...0,51....64
№25...593.........42,4.....11,1....0,56...0,53....56
TFR8-800, №26, №27.
........Re, Ом;.....Fs, Гц;.....Qa;......Qe;.....Qt;...Vas, л.
№26...1500.........61,9.....12,4....0,51....0,49....46
№27...1500.........59,3......8,9.....0,52....0,49....53
Suspension translucent, thin cloth. On measurements frequency response and harmonic distortion. Improved high-frequency diffuser. Subjectively, much better.
On line impedance in the ultrasonic region has maximum impedance at the frequency of 90 kHz at 9,2 kOhms. Next - to 200 kHz resistance of 2,9 kOhms.
Measurements №26, №27. (The new version of the speaker.)
Improved high-frequency cone design.
The results of precise measurement.
Phillips 9710. Comparison of high-resistance (700 ohms) and a low-resistance (5.7 ohm).
https://www.youtube.com/watch?v=TkS1bWu6maE
https://www.youtube.com/watch?v=47mq6hMpLZ8
Article:
Phillips 9710 ??? 700Om vs 5,7Om.
Article:
Congratulations on an incredible development.
Much more so for such good results 🙂
That very even frequency response is to be commended in any full range speaker; getting it in a high Z speaker is going beyond the limits.
Just curious, what diameter wire was used to wind the voice coil?
Is it copper or aluminum?
Thanks.
Thanks.
I am interested in an update on these high impedance speakers.
Are they available for purchase?
Jim
Jim
Hi, Jim.
Thank you for your interest in the subject. I apologize for the long absence. There are problems that are not relevant to the topic. I can make high-resistance speakers on request.
While in small quantities.
A comment about high-Z speakers...
Some people like John Broskie says that a world needs is a good 100R (or so) speaker (see The Tube CAD Journal, Hybrid amplifiers , for example), basically related to OTL world. Even in this forum I've seen this comment several times.
But I say that the audio tube world need is a great 2000R speaker 😉😀🙂 . No need for high-current cathode-emission-exaust OTL amps. Since here is proved to be possible to manufacture speakers like this, and with great results, why no single one "traditional" maker offers some high-Z model, besides the cost? 😕
Interesting exercise, at least.
Thank you, DIYBras.
An option, is made of high-current cathode-emission-exaust OTL amps.
Preamp and two monoblock amplifiers "Cyrclotron 6P45C". One powerful tube in the shoulder. Without the case, on the chassis.
Load - 32 consecutive fullranges speakers of 4 Ohms.
A little over 100 ohms. 25 W power.
Measured the real emissions of several high-current tubes at 14.5 V.
Full-range speakers 5 ", 200 Ohm. TFR5-1-200.
Sound coil 1 ".
Low inductance is also, characteristic.
F, КHz,......Z, Ohm, №1....Z, Ohm, №2
0,2...........205...............210
0,3...........170...............170 (Zmin)
0,5...........170...............170
1..............190...............190
2..............210...............210
5..............230...............235
8..............245...............245
10............255...............255
15............260...............260
20............270...............270
40............340...............340 (F2z)
........Re, Ohm;....Fs, Hz;......Qa;.....Qe;.......Qt.....Vas, l.
№1......160.........130.......4,02....1,35.....1,0......-
№2......155.........132.......4,05....1,47.....1,08....-
Sound coil 1 ".
Full-band speaker 6 ", 50 ohm.
Sound coil 15 mm. Outputs of the wire from the coil are ribbons.
In the amount of 32 you can combine the connection.
From sequential - to parallel.
Getting different resistance. Even 1600 ohms.
........Re, Ohm;....Fs, Hz;....Qa;.....Qe;.....Qt....Vas, l.
№1......39..........92........6,4.....2,6.....1,8....-
F, KHz,......Z, Ohm
0,2...........42
0,3...........42 (Zmin)
0,5...........43
1..............46
2..............54
5..............65
8..............70
10............73
15............75
20............77
29............84 (F2z)
F, KHz,......Z, Ohm
0,2...........42
0,5...........43
1..............46
2..............54
5..............65
8..............70
10............73
15............75
20............77
- Full Range
- Speakers full-range with a high resistance.
