Sowter transformer 8347 I/V stage fot TDA1543
Hello all.
I've built a DAC based on a CS8412 and a tower of TDA1545 (8).
I was planning to put a transformer I/V stage with a Sowter 8347.
All is working when I put just one transformer on one of the TDA1545 output but no sound when I put the two transformer on the two channels !
Is somebody have tried this before ?
I think that Audionote have made the same thing.
Kind regards
Thank you for your replies all.
The thing I do not understand is that when I just connect one channel output of the TDA1543, all is working. Tight bass, clear high, really sound great ! But, with the two channels output connected (so the two transformer connected at tht two TDA output) no sound at all ! Just noise ...
hi,
let me share a little bit opinin. My new full balance dac will use.
1.transformers IV.
2.Op-amp>>>>> transformers output.
3. OP-amp>>> 5687 cathode follower>>> caps OUTPUT.
4. Op-amp>>>>5687 cathode follower>>> transformers output.
this is the first op-amp link with transformer output.
pls see the photo show with the connection method between OP & transformer.
Transformers that I use was 1+1:1+1 10ma Max
thx
thomas
That's true PHN. This doesn't explain at all why this really good work with just one channel.
I have seen too at th Sowter website that I could use a 25 ohm resistor, but what about TDA1543 ?
I have seen too at Sowter that this transformer has been designed for output with a DC component (current or voltage), so I am correct by connecting these transformers without a DC blocking cap ?
I have tried with one and all is working ! All two channels but there is a terrible lack of bass !...
Is Sowter making bad transformers that doesn't support DC offset ?
hi elec-tron2,
sorry to distrub U,
U said lack of bass was talk sowter or my connect?
pls make sure sowter can run dc. Otherwise the core will saturate. I also test 8347f, if pass current looks not good. In my design & est. although I use 1+1:1+1, but this is not a Push Pull ytans. It is a SE trans, can pass Dc. so change Resistors on the pri & sec can adj te sound.
thx
thomas
hi elec-tron2,
U use 8 pcs of 1541a??
sorry I hadn't careful read your message.
Pls use back one 1541a first. I also try this sowter but looks this transformers cannot running any current, pls use a small cap to block the DC, such as phn said, adj the resistors between pri & sec can easy to test. during I test my dac, I also use two fine turn to trim the resistors value. If U had scope to compare will much better.
pls trust Brian sowter, he will not sell fake & Damn transformers
But this transformers was little weak in bass was right. That why I finally use large core to made the IV trans & pre-amp trans.
thx
thomas
I was wrong about the 200mA. Should be 20mA!
Anyway, I don't think the transformers can handle more than one TDA1543.
Sowter says:
PEAK SIGNAL CURRENT (with 25 ohm resistor): +/- 2.0 mA
The Burr-Brown PCM67 (one of the DACs the transformers were designed for) datasheet says:
ANALOG OUTPUT: Output Range (±3%) 1.2 mA
The TDA1543 has about twice that.
Hello tube-lover
I am using 8 pcs of TDA1543 but like PHN said, I have changed this afternoon to just 1 pcs of TDA1543.
But always not sound at all with the transformer.
I know that Brian SOWTER doesn't sell fake transformer and I know that they are considered as good transformer.
I am not able to get sound with that ! With nlocking cap there is a lack of bass ! And a strange think is that this has worked with 8 pcs of TDA1543 but with just one channel output connected to one transformer. When I connect the two transformer, sound disappear and let place to noise...
With just one TDA, no sound at all, even with just one TDA1543.
I was thinking that most DIYers have tried this I/V stage.
