SoundStream TA1.3000D
Just got this amp in. The owner stated that there was a "little something wrong" with it.
I first made sure that there was no continuity between B+ and GND.
I removed the cover and checked all MOSFETS on diode check and then with the ohms setting and all checked good.
I applied 13.8vdc @ 2A current limit. It maxxed that out, but I was able to see good square waves on the power supply FETS and it was building rail voltage.
I increased the current limit to 4A and it powered up with no problems pulling 2.68A with the remote on and has +/-77.2 vdc rail voltage.
I input a 50Hz sine wave @2vpp and have a good output signal.
I started increasing the gain and as I got to 160vpp, just before clipping, on the outputs I can hear a "buzz" and the peaks of the sine wave get "squiggly".
I do not have a load on the speaker terminals.
I can't pin down exactly where the buzz comes from, but it is in the area of the output filter caps and inductors.
Any clues on where and what to check next?
The inductors are solid. Zero movement. No change in output.
The output wave forms were with the scope set to 50v/div, 5mS and a 10x probe.
The "noise" on the heatsink was with the oscope set to 1v/div and 5mS. Scope ground on the speaker negative.
The 8 ohm loads in parallel should be a good start. I have used the large cylindrical 100w wirewound resistors for this (with forced air cooling) and they could take this sort of power short term. I don't know if the ones you have can take it.
Just a few seconds with a sine wave should show if there is a serious problem. You could test with music and the resistors should be able to take the power for longer. Testing with the woofer with music would also be good.
With the 8 ohm loads in parallel, the amplifier started clipping at ~120vpp.
The "buzz" noise is still present just before clipping.
Couldn't test long. The dummy loads get very hot quickly. They need to be mounted to a heat sink.
Is it possible that a capacitor could make that noise?
I can't really see a bulge on top of one, but it kind of feels as though one is ever so slightly bulged on top.
It's the one on the right in this pic with the black dot.
