It was tied on the low sum mono I put on the normal crossover and now it sounds normal in 0. Can low sum mode phase the sound?
Mono sum output of the crossover should work fine, how were you connecting that to both channels of the power amp? Did you use a splitter cable?
I tied the stereo without a splitter and only when I go low sum I have to press the invert buttons. In normal it is 0
Exactly how did you do that?I tied the stereo without a splitter
ev q44 on electrovoice lab gruppen on subwoofers, in ev I put the plugs on the outputs and I went to crossover and from crossover I go to lab gruppen.
You're not understanding, I want to know what cables you used to connect from the crossover to the amplifiers.
On the rear panel of the LAB there are 3 pushbutton switches right in the middle.
The left switch applies a 180deg phase shift to output B... make sure this is not on.
You probably do want to set it for parallel operations though, so the middle switch Link A-B should be on.
is left on normal, everything is left at 0 without low sum, everything is in phase ie tops plus subwoofers, this happens when I apply low sum , then I have to press the reverse button otherwise they are out of phase
cables XLR normal. the thing is that the ev boxes leave them fullrange and then I think that the frequencies overlap with low sum activated it s possible.
- Subwoofers
- Sound System
