Sony vFET Amplifier Part 2
While i admire immensely your aesthetic talent....and would like this amp to be look so special as it is ...please listen to ZM ...and read EUVL's paper on heat-sink heat distribution.
If you can combine all this with a truly unique and gorgeous design ...man you are the man. !😀😀😀
Actually Euvls paper is based on some lab work I did for him. Except I mapped the entire heatsink through laboratory measurement.
He then came up with a way to mathematically model it.
So yeah as it has been said repeatedly, it is best to space mosfets further apart for best efficient use of heatsink.
... Mr. Fantastic... oups, not me, but the new design!
300mm length, TO247 or TO3 for IRF/P...
... this is the End (sorry Jim)...
300x100mm; only THT components; some more reservoir and filtering capacitors should be equipped on the board.
I´m curious about comments?!
I will switch to the B1-BUFFER...
when i flip those 2 vfet, tadaaa the G and S position is opposite to KD-33. is this possible?
Just received 2 x 2SK82 from Ebay seller "polida2008" and I'm sorry to say, fakes again.
They look exactly like yours with good JA-33 printing, but when flipped the G and S is opposite.
Put a drop of Isopropylalcohol on them and you wipe off the text completely 😡
Then I measured them and yes, relabeled 2SK60s again.
I stop here, no more VFET's from Alibaba or Ebay for me.
isn't 2sk60 a vfet as well? So if it works, it can be used in a different design?
you are not as greedy as me, I bought 4pairs which cant be returned. Well if it's 2SK60 then at least it can be used someday, who knows Papa will release another vfet version :drink:
