i need a service manual for a SONY CDX-M8800 .
the big flourescent screen died on me when i started the car
something wrong with the car electrical system !
i fixed the screen (the transistor that was driving the smps for the vacuum tube died) but i touched two pins from the connector going from the faceplate to the main board , one of the pins is rated OPEN and the other -10V .
now the open button an the faceplate doesnt work and if i start the HU from the remote none of the buttons on the HU work only the remote buttons ! and if i start the HU from the faceplate the remote does not work ! only the OFF button then i have to push SOURCE and start it from the remote
Hello, please would you tell me the code and name for transistor that is driving the smps for the vacuum tube, my has burned out and i cant find schematics for it.
sorry for my bad english
Sony cdx-m8800
cableguybl
cable@teol.net
Sony cdx-m8800
cableguybl
cable@teol.net
i don`t have the code because mine was destroyed !
i replaced with a BD139 i think or BD140 ! it is NPN or PNP can`t remember witch
it works great now
cdx-m8800
I found scheme for sony cdx-m8800, if you need just e-mail to me and i will send you.
Cable@teol.net
Cable@teol.net
the transistor is a BD139 . i think it would be better to put a mos-fet but this is the only one i had .
thanks
thanks
I send you tvice allready, i wiil send you again, file size 6 mb.
Today i wiil send you again.
- General Interest
- Car Audio
- Sony CDX-M8800
