ScanSpeak 15W4531 would be a good contender as a replacement. You'd have to check DCR to verify impedance but the low Qts and Fs are fitting for the smaller box.
Thanks guys for all your help.
I checked and the woofer is 4ohm so the correct replacement should 15W/4531G00.
I will give one week to SF to reply.
In the meantime I will ask Dibirama for additional information.
Thanks again... DIYAudio is an amazing community!
Enrico
Enrico
Well, I was too pessimistic... SF customer service reply to my request.
They address me to their authorized service center:
www.triodo.it
service@triodo.it
Maybe can be useful for others...
I just ask for a new part.
Let see what they reply, I will keep updated
Enrico
www.triodo.it
service@triodo.it
Enrico
I double checked that SF part number with the old replacement parts list I had and found out the part number I gave you was close. The shielding does change the motor specs a tiny bit. Its enough to hear a difference in the lower mids.
Be aware that sometimes service centers don't like to just supply the part without any labor. I don't know exactly how the laws are in Italy but that's how it is in the US. When I was a tech in Germany, we had to sell a part to a customer if he requested it. This was however in the late 80s to early 90s.
In this case the differences are likely very, very marginal. I doubt anyone will hear any difference. See the attached DS for 8Ω versions…The shielding does change the motor specs a tiny bit. Its enough to hear a difference in the lower mids.
So, the situation is evolving very fast!
I get a reply from Triodo customer service SF. The original speaker will be available in 45 days at 767 EURO plus shipping!!! 😱
I found also a Scan Speak distributor in Thailand and I am waiting his reply for availability. Price 226 EURO plus shipping.
In the meantime I write to a friend here in Vietnam asking for help with custom clearance that it's a real nightmare.
He is a doctor that I meet in one Hi-end exhibition in Saigon.
Look like one of his patient is the owner of the best speaker repair shop in Vietnam!
Today I will send him the woofer... let see if I am so lucky to get it repaired!
I will keep you posted
Enrico
Enrico
What is the problem, what is "broken"? A picture maybe?Today I will send him the woofer... let see if I am so lucky to get it repaired!
So it's not "broken", mechanically everything is complete.
I bet the problem is the glue they used. That glue usually corrodes the thin wire of the coil itself. The solution is to unwind a bit of the wire from the voice coil or add a piece wire and connect again to those flexible braids. Any quality repairman can probably fix that. If it comes to that. This is a known problem with Scanspeak, especially in more humid climates.
I have a ZRT build with two Scanspeak Revelators bass elements on each side. Last time I went to use them there was no bass. Initially I thought there was something wrong with my NAD D3020, but tried with a different amp and realised the problem were the speakers. They are about ten years old, from Madisound Speaker store.
When taken out and measures with a multimeter, they all show open circuit. They have, to my knowledge, not been playing loud and I can see absolutely no damage on any of them (except two of them which has some unrelated cat scratch cone damage). I read somewhere that...
- Sonus Faber Cremona Auditor - HELP
