Son of Zen and math
10 years a go i posted on this thread 🙂
SOZ is rad amp. SOZ is BIG amp! no getting around the need for dissipating lots of heat.
Mount power resistors on their own heat sink. Then FETS don't have to share. put a fan on them if needed. Big PSU too 🙂
i'll check back in another 10 years 🙂 🙂 🙂
Thanks for reply moe29! 🙂
Yes, its with SOZ as its with everything else.. "no free lunch"!
Looking forward to hear from you in 10 years! Maybe I have built a SOZ by then! 🙂
By the way, forget #41, it`s wrong!
So, tried "Half Son of Zen"
Had the parts, and did not take to long time to build 🙂
It plays music but should probably have 8ohm resistor instead of 10 and higher PSU voltge to get "sweetnes".
Know you guys in here said so, but had to give it a try! 🙂
Gain is also very low.
Spot on Zen! 🙂
Thanks a lot!
So got this schem from papa himself!
Thanks a lot to papa also!! 🙂
I named this one "Simply Zen".. 🙂
8ohm resistor is the speaker by the way!
Will give it a shot when I get time!
