I am absolutely gutted, the wife has run off with my best mate.
And I am really going to miss him.
The meteorologist that discovered wind chill factor died this week aged 82. In a recent interview he said he only felt 64.
This may not be mood lightening.....
Home skills every girl should be taught:
1. How to change the locks.
2. How to disguise the taste of arsenic.
3. What a restraining order is.
4. How to disable an attacker.
Teach your daughters well.Today I was excited about powering up my fine tuned p3a, had breakfast and went to my cave, looks like my assistant was working late last night.
Will do some gardening instead.
Cal,A blond is standing on one side of the stream, a brunette on the other.
The brunette asks the blond: ”How do I get to the other side?”
The blond giggles and says: Silly, you’re already on the other side”
Do you know what you call a smart blonde?
Easy with the big words.The meteorologist
Given the current subject matter, let's keep the necessary level of comprehension appropriate to all genders of any chromatic hair expression, as suggested below.
Carry on.
Only for hardwoods, right?That unit of measurement is only used for wooden erections!
IIRC, there's a smaller unit for softwoods.
You should guess what's happening inside.I see knobs but no meters...
There are about 38 knobs, and if we assume each knob has 10 positions, then there are 10 * 38th power of possible setting combinations.You should guess what's happening inside.
Your chance of guessing correctly is, well, slim to none, as you may have already experienced.
Yes, I know some knobs go to 11, but that only makes matters worse.
- Member Areas
- The Lounge
- Something to lighten the mood
