How is that possible ? The motor comes from ScanSpeak Illuminator series and the cone is produced in house or by a neighbor facility. There is nothing secret about the YG Acoustics BilletCore Cone. I have personally held the cone in my hands and inspected it.
It was a joke
No, it's not. At best it would be about even, and at worst it would be significantly lower.The cone material that they need to use is hardened steel. Its stiffness to weight ratio is significantly better than aluminum, and the breakup frequency would be extremely high. It's also extremely consistent material.
In regard to the Purify audio PTT driver shape and the surround. Notice the shape of the high end Technics R1 loudspeaker bass driver surround and those drivers are 6.5 inch- is this a coincidence or the same designer? https://stereotest.nitschkeverlag.de/images/product/000792.jpg
In the meantime, here some data on the SB19STCan you please do the SB Acoustics SB19ST and Wavecor FR084WA01 next?
Sparrow-19ST (SB Acoustics SB13PFC25-08 with SB19ST-C000-4) – AmpsLab
I don't have them, so sorry..🙁
A good noting. It seems the Fostex FE168EZ has a similar technology too -In regard to the Purify audio PTT driver shape and the surround. Notice the shape of the high end Technics R1 loudspeaker bass driver surround and those drivers are 6.5 inch- is this a coincidence or the same designer? https://stereotest.nitschkeverlag.de/images/product/000792.jpg
Fostex FE168EZ 6.5" Full Range Sigma Series
check out the sb21sdc, it looks super
SB Acoustics SB21SDC-C000-4 | HiFiCompass
SEAS 27TDC/ 27TFF has lower harmonic distortion, but SBA typically has better off-axis response.check out the sb21sdc, it looks super
SEAS 27TDC (H1149) | HiFiCompass
Has some weird behaviour going on in distortion plot around 1.2 kHz.check out the sb21sdc, it looks super
Are you sure ... I don't see any specific issues at 1.2kHz.Has some weird behaviour going on in distortion plot around 1.2 kHz.
Look at the 4V and 5.6V HD plots.Are you sure ... I don't see any specific issues at 1.2kHz.
sure, it may look bad on the plot, but is it even audible if you cross it at 3khz to the mid driver?
the vifa ne19vts looks good other then a h3 spike at 7khz, 1% dist at 98db, will this make the driver sound crap and unusable? Vifa NE19VTS-04 | HiFiCompass
That spike will be at 21 kHz. Not audible. Does look like a good tweeter.sure, it may look bad on the plot, but is it even audible if you cross it at 3khz to the mid driver?
The problem with crossing at 3 kHz is that you’ll have a large null off-axis at the crossover frequency due to the relatively high center-to-center spacing. With a lower crossover frequency the null gets smaller.
I thought it would be fun and instructive to share a video from this years BAF. at 1h20min Demian Martin starts to talk about measuring loudspeakers - Bob Cordell is before him and talk about measuring amplifiers. Enjoy.
YouTube
I think, it's very useful presentation for newcomers🙂
The measurements of the Tectonic TEBM46C20N-4B fullrange speaker have been added:
Tectonic TEBM46C20N-4B | HiFiCompass
- Some speaker driver measurements...
