New version now available.
Specifications:
-Size: 1.5”x1” (38x25mm)
-Input voltage range: 4.5-24V
-Efficiency: 90%
-Power: Limited to 2x21W(8Ω) 2x52W(4Ω) @ THD:10% (22V).
-Minimum THD: 0.05% at 0-2W
-Standby current: 50mA
-Sensitivity: 1Vp-p (@20dB)
-Gain: 20dB/32dB (selectable)
-Input impedance: 60KΩ (20dB), 15KΩ (32dB)
-Minimum load impedance: 1.6Ω
Features:
-DC offset detection at output to prevent speaker damage
-No ‘phone buzz’
-Includes comprehensive instruction manual.
-Hand assembled and tested in the UK
-No turn on pop
-Full L-C output filter with EMI snubbers
-Optional differential inputs (selectable on the board)
-Microcontroller on board for error reporting and precise turn on delay
-Status LED. Solid light when amp is “on”, flashes when amp reports a fault
Full specs and info on my store page: http://www.io390.co.uk/product/25w-amplifier-v2
Price is £24.99 plus postage and includes a full set of connectors.
Thanks for looking!
Specifications:
-Efficiency: 90%
Features:
-No ‘phone buzz’
-No turn on pop
Thanks for looking!
Yup, that's the sound of ferrite, IME/IMO the spoiler for class D amplifiers.They have tighter bass than the previous version with ferrite beads, which had a "deeper" sound.
Ditto, ferrite cored crossover inductors.
Nice design/implementation.
Dan.
Very nice work! Those sure are cute and would be great in almost any portable app. This would be one heck of a headphone amp (5v supply) for someone wanting to make their own cans using 2in fullrange drivers! Vifa TC6FD hmm....
What does shipping to US cost?
Thanks for the kind words
Shipping to the US is £3.50 ($5 roughly) for 5-7 day. Anything quicker is a lot more expensive. Info on shipping is on my shop page.
Thanks for the info on shipping -$5 is very reasonable. I noticed that the pin out on the speakers shows + - - +. Is that correct ? On the 3116 it is + - + - and Sure actually mislabeled their boards. The 3132 may be different though.
Definitely correct: http://www.ti.com/lit/ds/symlink/tpa3132d2.pdf
This is the fifth board I've made with the TPA3132 (only second that I've sold online), so I should hope I haven't been getting it wrong this whole time
Since the inputs are differential you don't have to run the signal input to the positive input on the chip. If board layout is better with signal input feed to the negative input instead then you just relabel the outputs instead.
Really good work! I've ordered 2 (sent you a message about possibly specifying the wrong gain level in the order form)
I like the idea of the 1x1" version even if it seems like no one would have a use for something so small, you never know.
At that size, you could call it the stAMP.
There was a lot of todo over on the Speakerplans forum about 'The Vamp' (http://www.thevamp.co.uk) mostly over the rubbish component selection versus high cost/marketing driven approach. A one inch square amp would be perfect for a gadget like that where there are few other limitations on the size of the enclosure.
There was a lot of todo over on the Speakerplans forum about 'The Vamp' (The VAMP® | Transform any speaker into a portable Bluetooth® speaker) mostly over the rubbish component selection versus high cost/marketing driven approach. A one inch square amp would be perfect for a gadget like that where there are few other limitations on the size of the enclosure.
Replied to your email.
I like your name idea, it's not far off already:
I could have a go at a 1" square design, can't promise anything on that though.
Looking at the Vamp thingy, how big actually is it? Also what's the output power etc, the website seems to be 100% fancy graphics as opposed to anything useful.
I think it's around 60-65mm cubed with a slice cut off. Output power was listed as '4 watts peak' in their Kickstarter campaign (which raised a lot of funds, followed by a 5 month delay for delivery and quite a lot of bad reviews) but they quickly dropped that (and all other meaningful specs) from later promotional material/manuals.
Only so much one can do with a USB power supply I suppose. I've never designed anything which draws more than 500mA from a single USB socket, and at 4W that's nearly an amp current draw...
I read that there is "less bass" with the bluetooth. I find this surprising, as the BT signal is digital. Packet loss perhaps? Also the interface circuitry between the bluetooth module they're using to the amp will have a say in what happens.
"4W peak" is 400mA current draw. And that's probably into an unrealistic 2 ohm load and with 10% THD or worse.
The bluetooth module they're using could have incorrectly dimensioned output capacitors if they picked up a standard cheap module meant for headsets which seems likely. That would account for the missing bass over bluetooth.
Or thereabouts. Still not ideal from USB IMO.
Funnily enough the topic of USB as an appropriate power supply just came up on another thread, so I'll paste what I wrote on there:Only so much one can do with a USB power supply I suppose. I've never designed anything which draws more than 500mA from a single USB socket, and at 4W that's nearly an amp current draw...
*most* portable speakers that charge via USB will have a small amp in the region of 3 Watts.
You've generally got to look to the £70+ price bracket but if you search (and research) you will find many [speakers with a 10-20 Watt output and USB charging] After a while you get a feel (based on a balance of price, claimed specs, manufacturer reputation and customer reviews) whether the Wattage ratings are legitimate or not. Many aren't. Some are.
12 hours of charge at 500ma 5v will give you 30 Watt/hours of juice, if you're using a 90% efficient amp (call it 75% to factor in quiescent current and lower efficiency at lower output levels) that gives you 22.5 Watts to play with. Average music program is about 1/8th of RMS signal so we can multiply that by at least 8 (more if you're high passing around 100Hz as many small speakers do), giving a total of 180 Watts equivalent, or approximately 12 hours of continuous 15 Watt program output per 12 hours of charging.
In the real world due to the significant bass cut below 100Hz, (where most of the musical energy is in modern music) you could expect to get that 12 hour output from a 6 hour charge or even less.
Some of my estimates may be significantly off but I guarantee it's in that ballpark. USB is a perfectly viable medium for charging speakers.
As I say my numbers are probably way out but basically if the device has a battery (greater than 5v) inside that works as the buffer for the USB charger, and in normal use (most don't play their devices at maximum volume all the time) the balance of charging versus mobile use tends to be acceptable (at least 1:1 usually 2:1 or greater ratio of play time versus charging time)
- Vendor's Bazaar
- Some more really small amps
