I can't see any shorts on the QPN pins with a magnifying glass. The caps look intact and measure 441/442 uF.
I don't think so. It had a good centimetre gap on every side. I had metal standoffs (all I could find), but used nylon washers. The board was only handled by the edges and the polarity of the power supply was carefully checked.
I could give it another go, sitting it on a non-conductive surface.
Update: Still the same. Ticking sound seems confined to left channel.
OK, I have no idea what's happened but I'll send you a new one on Monday.
If I include postage, would it be OK to return it so I can see what happened?
Of course. No need to include postage - the stamp wasn't franked ;-)
I like your style 🙂
What value/type of potentiometer would be optimum for your amp, assuming 20 db gain, 220 Ohm/2 Vrms source? I have a nice 100k pot from another project. Would that be a mismatch?
I see no reason why 100k wouldn't work, the input impedance at 20dB is 60k so a 100k pot should be just fine.
Have a look
DACT Attenuation Curve Calculator
Thanks! According to the calculator, as long as my cable capacitance is under 400 pf, I should be OK. The trouble is, I have no idea what my cable capacitance would be. 🙂
I wouldn't worry about it. As long as the pot is less than a few feet away from the amp (which I assume it will be) then you'll be just fine.
New stAMP received, installed and running like a dream.
Fantastic customer service - thanks Sheldon.
You wouldn't get that from your average Chinese supplier.
The EMI filtering must be doing its job as the amp is powered by a laptop supply and sits behind a TV and on top of an STB. Again - no hiss, hum or crackle.
- Vendor's Bazaar
- Some more really small amps
