Managed to massage the board into an existing remote controlled pre-amp built some years ago.
zei said:Massage mmm 😎 😉 😀
Looks great!
/JZ
zei,
can i use a 16V tranny and regulate it to 15V using on board regulator?
Zei. You reccommend 15v for the ppower supply. The NE5532 for instance takes a max voltage (I think) of 16v. I am under the impression that an op-amp will run with say 5v? If this is right what benefit is there from running them at higher voltages?
I,m not shure what (if any) benefits there would be running an OpAmp at lower voltage (Within the recommended range of course)
Most of the times all this info is in the datascheet but i think that the only reason that they can take a range of different voltages is that it increases the numbers of applications they can be used in.
If i remember correctly the E5532 max voltage is +-22V
Opa2134 has a max V of -+18V
lets hope someone else has something more intteresting to say about this 🙂
I say +- 15V because it is a number 🙂 No other reason 😉
/JZ
/JZ
The reason I ask is that I used parts I had to build the soap. One of the variable resistors will only give me 10v max. However there is no volume in-balance.
Puffin said:The reason I ask is that I used parts I had to build the soap. One of the variable resistors will only give me 10v max. However there is no volume in-balance.
BUMP
I would also ask if this Pre has any DC on it? I am getting a bit of cone extension on power-up
You power the preamp after the poweramp is powered?
If powered before thrn i have not had this issue.. and none else that i heard of.
Are you using caps on the output?
/&JZ
/&JZ
I have never had a problem with this, but it may have something to do with your sensitive speakers, or an inferior build
I had assumed that the caps at C15 - C18 might have been to provide DC blocking. I assume I am wrong. If I add caps on the output, what values do you suggest.
Trippy. For safety purposes I wear thick gardening gloves and use just spent matches to solder with as my mum told me not to play with hot things as I might hurt myself. My PCB's look like burnt pizza.
Puffin, I have a PCB just like yours but with a slightly different topping, if you know what I mean?
They say you cant educate pork! 😉
Anyway...where are all the other builders posts, its been three weeks since I built mine, I'm sure Zei will be keen to know how you are all getting on 🙂
Richard
Richard
Puffin said:How do you find yours after 3 weeks, any significant burn-in differences?
Puff meister
During the first week I used 2.2uf Vishay capacitors at positions C15 and C16 and a pair Icel MWR 4.7uf caps at C17 and C18 (as pictured in a previous post), The sound was OK but I felt the bass sounded a bit flabby.
The following weekend I purchased some rather nice AMPOHM 3.3uf polyprops at an Audio Jumble near Leatherhead. That evening I decided to de-soldered the old capacitors and replaced them with the AMPOHMS...What a difference! the bass became tight and deep, there appeared to be a higher level of detail I had not previously experienced. I then swapped the OPA2132PA for the LM4562...yet again a noticeable improvement.
I auditioned several opamps, the OPA2132PA (FET), OPA2134, AD826ANZ and LM4562.
I didn't like the AD826, the OPA213PA sounded nice and the OPA2132PA had a warm signature but lacking the crisp sparkle of the LM4562.
I am currently making some aluminium cases to house my Chipamp and SOAP-Pre, I will post a couple of pictures when completed.
Richard
Alternative to Black Gate N/NX for SOAP
Hi Everyone,
I am having trouble finding 4.7uf N/NX Black Gates for coupling. The AMPOHM 3.3uf sounds great but I'm in the US. Does anyone know a source for the Black Gates or AMPOHM in the States or a good alternative cap for the SOAP mkIII that's availabe here?
Thanks for all of your posts. It's been very educational.
Ciao -- M
Hi Everyone,
Ciao -- M
Did you have a board left, and if so how much with shipping the the US?
After seeing and reading about it I think I have talked myself into one of these...
zei said:I,m not shure what (if any) benefits there would be running an OpAmp at lower voltage (Within the recommended range of course)
/JZ
zei,
If I'm using a 15V tranny would it be possible to remove the trimpot????
Do I have to adjust the voltage if decided to keep the pot?
- Chip Amps
- SOAP MKIII (Simple OpAmp Pre) With onboard PSU
