SOAP MKIII (Simple OpAmp Pre) With onboard PSU
Thanx Kanifee!!🙂 It looks great.!
Regarding the rectifier, The choice of rectifer dios is your of course, If you want to use fancy nancy superfast diod then why not. 🙂 However, "normal standard" rectifier diods also work 😉
Regarding the BOM. You will al get an "up to date" BOM and i,ll see if i can add partnumber from Farnell or something like that.
Deadhead, You got mail as well.
Thanx,
I,ll order the boards this weekend
/JZ
Here's my effort on the SOAP MKIII, based on the files kindly given by Zei. Thanks a lot.... I will test it this weekend, if time permits.
However, I noticed (after construction) that the design does not have a low pass filter at the input, instead it has a high pass filter (formed by C1 and R1, R2 and R3. What would happen if the position of C1 and R1 is reversed (and values adjusted accordingly) so that a low pass filter is formed? Feedback from the original designer and/or Zei will be much appreciated.
I want to use the SOAP as a pre-preamp for my el-cheapo MP3 player (powered by a single AAA battery) as the MP3 player's output is too low to drive a preamp (gain of 3) directly.
Hello,I would like that you send me one PCB to Seville (Spain).
Can you tell me what I have to do?. And how I can to pay and many money (€).
I am very interest for this preamp.
Thank you.
Regards.
Carmelojose
P.D. My english is not very good,I´m sorry.
Hi
I have just started putting together a Farnell parts order now that I have received the latest BOM spreadsheet.
I have a few questions for the experienced amongst you…
Resistors
I currently have a wide range of 0.25w metal film resistors in my parts bin. Which resistors need to be of a higher wattage and what would you recommend?
Capacitors
C11- C14 = 100uf
Should I use a general purpose cap here or would I benefit from a ‘Low ESR’ cap like the Panasonic FC?
The reason I ask is I have heard OPAMPs can become unstable if the ESR is to low. I assume its best to stick with a rating of between 35/50v in this circuit.
C15 – C18
Can anyone recommend a good quality capacitor that can be sourced from Farnell?
Transformer
What is the recommended voltage secondary value? Is 18v to high before rectification?
Thanks for your help
Richard
Hi Richard 🙂
I heard the Pin. !🙂
For C11- C14 = 100uf - You can use Pana FC.
For C15 - C18. You can get away with Wimas, Or more cool ones like BG, Paper in Oil etc.. I would have started with something cheap 🙂 And then maybe maybe upgrade with fancier stuff.....
35-50V for caps works..
18V transformer is also ok 🙂
/JZ
zei said:
Hi Richard 🙂
I heard the Pin. !🙂
/JZ
Thanks Zei
What about the resistors and Trim pots? What wattage should I use? What, what, what?
