So, what kind of internal speaker wire are you using?
AJ,
I do appreciate the compliment. What you see was totally made from scratch. The boards were made from Corian that I had in the shop. They were then scribed with an awl to make a grid to work with. Epoxy was used to set certain parts in place after drilling part way into the board. When I was about finished, I did the thump test, and sure enough could feel a good amount of vibration from the suspended wire wound resistors. A ceramic support was used to stop that. In other words, more time (and hopefully quality) went into this than I anticipated from the start.
Waxx
"Silver wire also work, but is not better, it's actual worse as it rasises the treble, but so minimal that it's hardly worth thinking about it."
Are you saying that in your view silver wire "creates" excess treble, and that this is not actually there in the original signal?
As far as I can see, that would be difficult, I've always found silver interconnects just more resolving. So this would infer that copper leads "dulled down" the HF previously.
I have never come across a measurement that shows silver or copper favours and frequency range over another, but I'd have to want a comparison to what was used in the mastering equipment during prepping a recording for release. Assuming I happen to use the same speakers, and playback equipment chain.
And assuming I wished to match what was intended.
I rather like the cable from Canford in the UK. It is made by them for pro audio installations and is available in a variety of CSA. It has nicely flexible outer jacket and cores and the strands are not too fine. It is black rubber with brown conductors marked for polarity. Since this is used internally the aesthetics are less important.
I use this in my active speakers, so the length is less than 1m to each drive unit.
In this application I have not observed any difference to the sound when changing cables, nor would I expect to. Expectation bias perhaps 🙂.
My amps have no output coil so the connection from amp to speaker is about as direct as it could be.
Reactions: MITsound
Nothing fancy, 8 or 10/2 or 10/4 SOOW. It’s nice and flexible, covered with rubber insulation, stranded. I’ve never been able to hear cables so I just use power cables. The only time I heard cables was when I lived in the humid south and my cables turned green due to the humidity. I swapped them out and the highs came back and the midrange cleared up. I’ve experimented with many cables and I can’t hear any difference. I made some custom braided cat 5 cables and was seriously disappointed after all that work when I didn’t hear any difference. I don’t have the budget to mess with $1,000 silver cables wrapped in cellophane. I think they’re silly anyway. After all, most of the classic loudspeakers simply used lamp cord and screw on terminals and they sounded great.
Back in the early '70s, my dad, fresh out of the RAF and having completed several more electrical engineering courses, landed a job down in London for one of the defence contractors making then-SOTA man-portable wire-guided anti-tank missiles. Apparently every significant connection in the main control gear was wire-wrap. Nothing else was reliable. Clamps were a very distant second, cold weld way down the road, solder -forget it. He left after about a year as he was doing fairly 'mechanical' line-work and moved into TV repair & thence became an industrial electronic engineer untll retirement, but the lesson on wire-wrap connections and their value under extreme conditions was one he never forgot.
Yes wire wrap is a great way to make connections. I worked on missile defense and missile warning systems in Cheyenne Mountain and they were connected by wire wrapping and installed in Air Force blue earthquake cabinets. Everything was safety wired and bundled with waxed string, no zip ties.
  • Thank You
Reactions: Ixnay and GM
You get a big thank you from me for the use of waxed string! Most all zip ties are a joke, with the exception of the stainless steel ones. And when you got done bundling, the result looked like a pack of cigarettes, nicely tied together.
Not all silver sounds gd.suffers same grain problems as ordinary copper which also sounds congested,diffuse and grainey.uppocc cu an ag from neotect are fabulos.there silver has crushing dynamics,transperancey in spades and treble harmonic illumination.downside,yes there has to be one,cost. Use neotech wire everywere. Dont shot the messanger.
Reactions: ScottG
Cal,, no, no, you got it wrong man. Cleaning your teeth with a laser is the only responsible thing to do in this age of technology.
But I will tell you, that for those of us out there that know the difference, the 9 cord as we called it was unbeatable for so many things.
When it comes to the internal cabling on most anything that can be a pain to access, I don't give it a second thought as to spending a bit more if needed. The choice of conductors to use is of course up to you.
