Magura said:
Exactly my thought....your circuit is fine.
Magura
Well yeah - I know it was your thought. I was just sneaking in to try and 'steal your thunder'
anatech said:Hi Jason,
Well, there you go. Some experts on this design have weighed in. So, did you match those transistors? If so, how close did you get them?
-Chris
However much I hate the idea of not matching the fet's for a diff. pair, the fat is that it's not needed for this design.
I once tried just for kicks to mount two seriously mismatched fet's in a standard BOSOZ, it made no real difference.
Don't get me wrong, I still match my fets, nut I know that it's a matter of semantics, not actual need ;angel:
.....and it's naturally also a product of the fact that just about all my stock is matched anyway
Magura
Magura
:bs:
Hi Magura,
Well, you know I generally match transistors in certain locations whether they need it or not. I generally find improvements when I do and it only costs time when you buy a number of devices.
Like I said earlier, I'm not familiar with this design, but I may build one later on. I am becoming more curious about it.
-Chris
-Chris
Zen Mod said:
:bs:
Now let us hear it, have you actually managed to find fet's adequately mismatched to make a BOSOZ not work? If so I'm all ears, cause I usually tell people not to worry about matching for the BOSOZ.
Magura
anatech said:Hi Magura,
-Chris
When I buy a bunch of active devices, I take an afternoon out of the calendar, and match the whole thing. This way it doesn't take too long to do, and there are very few devices that don't have at least one match, mostly they match ind quads and more.
Magura
Magura
well - I didn't made any of these , except dreky one for Igor .........trying to save what can be saved from "othert one KoKy's" work
mismatched fets ....... they will be hardly audible, just because their tail in LTP is sooo long ;
but - mismatched fets can result in non equal current sharing between halves, further resulting in some resistors hotter than other.
I didn't say that I succeed in "making a BOSOZ not work" ..........
crazy danske
anyway - with jleaman is everything possible
Well, this far we agree
I really did my best to make a BOSOZ not work, in order to see for myself what I should advice people to do around here in Denmark.
So no matching mosfet's, mismatched passives, values a bit off here and there....and it still worked. That's why you had me wondering when you wrote BS I really did what I could, and it still worked
Magura
Magura
Magura said:Well, this far we agree
Magura
Yaa,
you'll end up with mismatched voltages to ground before the output caps. At the worst, it will limit swing - I presume.
And then it won't drive a F4
Oh bummer, now I'll have to dry my eyes again
Magura
mpmarino said:
Yaa,
Magura
it will - if you use it for F4 Mini for headphones ;
but - left earphone will be louder
Naaa,
Not if you equally mismatch everything
Joined 2002
jleaman said:For the second time, the fets are matched, The kit came with matched FETS and all the parts right from twistedpearaudio. So yeah.
The pre-amp is working fine, however i wish i could get more gain out of it
Jase
how much more gain you wish?
increase both R19 and R18 from 39K to 68K (or 75K) and you'll double the gain
anatech said:..............
-Chris
some say that variant with Jfets cascoded with eeny weeny BC critters is better sounding .
ask steen - if you can catch him
- Smoking HOT X-BoSoZ HELP!
