SMD components
The datasheet current figures are a joke - no way you can put 186A through a small package like this - MOSFET datasheets seem routinely to use die ratings rather than package ratings for max current. The bond wires will vaporize at 186A. There's significant specs-man-ship on power MOSFET datasheets alas. The datasheet I saw has a note (a) "package limited" but it doesn't appear to be used (so we can assume all the suspect values are die-limited).
To be sensible the package dissipation on a typical PCB is upto 6W or so for 10s only (datasheet) - most people wouldn't put more than 2W through such a package for reliability. That limits the current to sqrt (2/0.0015) = 36A, but again can the bond wires or PCB traces take that continuously? Questionable unless on a 2oz IMS board perhaps.
Anyway current ratings for MOSFETs are always assuming infinite heatsink and the extreme thermal limit - you'd never want to be in that regime continuously - in practice you determine the maximum power dissipation Pd you are happy with (given package and its thermal environment), and determine the max current from I = sqrt (Pd/Ron), using worst case Ron. And if switching rapidly you'd account for switching losses too.
Reactions: VT-52
I am looking at some SMD parts to make a test pcb with an Ideal Diode controller setup, using a 74680 controller (I need 6Vdc) and some smd MOSFETs. The fets are generally rated at a continuous Ids of 100-300A. Now I am in no way looking for those kinds of currents (10A continuous DC at most, if ever), but I was wondering how those itty-bitty little legs are going to carry 100-200 amps to begin with?
For example the SIR626LDP-T1-RE3 I am eyeballing; 60V and 194A in a tiny PowerPack-SO8 package. The drain is spread over 4 of those pins, the source over 3. I get the wide trace and heatsink pad on the back. Just not sure how any PCB trace with so little contact could handle in excess of 10A.
Anyone with experience care to share?
Probably by specifying the current under unrealistic conditions, namely 25 degrees Celsius case temperature, soldering the drain (back side of the die) straight to the exposed diepad without any bondwires at all and bonding the source with multiple unusually thick bondwires to each of the three source package pins. You need multiple thick bondwires anyway to get the specified 1.2 mohm typ., 1.5 mohm max. on resistance. If you want to spend half the budget on the package and half on the MOSFET die, that's 0.00075 ohm max. for the package including bondwires and leads.
The 150 mW maximum power dissipation you get at 10 A (or 210 mW when you use 4.5 V gate drive) should be no problem, as long as you use the MOSFET as a switch. Be careful with undervoltage conditions, when the gate-source voltage is too small to properly turn on the MOSFET, the power dissipation may get much higher.
