Slot ported version of The Tango
I guess? Will that solve the stuff? I might make both designs and not glue in the back wall wherre I'll temporarily put the port. The final design will have the port in the front if I can get the speakers to not collide phase wise. Should I be concerned about that?
Anna,
Looking at your figures above, I believe you have it correct: shelf port 0.45" high by 7" long. My best guess is that this should work just fine. (although you should remember what Ben Franklin said: Free Advice, worth every penny you paid for it.)
Changing from round to slot will have some effect--greater surface area means more friction with the air slug in the port. Dave Dlugos (P-10) uses this feature in his Fonken and related designs to good effect.
If you want to compensate for the internal volume lost to the thickness of the slot plate, you might add 0.3" to the height of the cabinet. If you want to do a round-over on the ends of the slot plate, then add a fraction of an inch to the length to compensate; exact length depends on the radius of the round-over.
Cheers, Jim
