Slone amp final solution ?
It does not drift when I blow on it and touching any transistor does not make a real difference.
Reducing R12 from 5k1 to 3k did reduce VAS current variations as now I can read between 10 and 9mA
Offset did not change as it wanders between 3 and -1mV
After trying Cordell's solution (4k7ohm between collectors of the IPS mirrors) and having verified that it also sets the VAS current with fluctuations, I decided to go back to my solution.
Reduced R12 to 1k and placed small heatsinks over the VAS buffers Q4 and Q6.
It is reasonably stable (it changes every second) but within 11.6m_A and 11.3mA.
I lost some dB in LF Loop gain and THD20 went up a bit but damping factor at 100Hz is 5k7 so bass is not compromised.
Now I will prepare the boards for installation in the P130 modular amp and proceed with listening tests.
Hi Ricardo,
We distinguish two kind of currents in case of a complementary VAS stage: the sum of the two collector (or emitter) currents (i.e. common mode) and the difference of them (i.e. differential mode). The latter, being the signal, is supplied to the next stage.
Regarding your current solution, please also have a look at this post about tradeoffs between open loop gain and amount of feedback (by mens of Rfb) to define/stabilize the common mode current.
Cheers, E.
Your solution is quite complex....
With 4mA in each input jfet I am having trouble to set VAS current lower than 16mA
I managed to have the same vdrop over the mirror resistor R2 and the VAS emitter resistor R11.... but....
Increasing VAS Re to 47ohm gets me in the ballpark.
One thing your circuit provides is very good stability even with TMC... With local feedback set to 10k there is ne phase dip below UG... very good.
Did you build your circuit Edmond ?
Does the current limiting Q11 Q16 stiffen the VAS DC common mode current ?
Nice to hear.
No. I don't like building amps that much. I'm a designer in the first place.
Under normal conditions current limiting should be completely off.
Cheers, E.
Happy New Year.....
Please look at my latest design.
It does not need local feedback.
VAS current is set by a mirror based CCS so it is independent of IPS current.
OLG is maximized so THD is minimized.
The only doubt relates to the connection of the VAS buffer... it is almost like a darlington but not quite.
Hope you have the time to look at it and let me know if it can be done 🙂
  • RCP130 BIEL FCS VAS CCS EVO8.62 TRANSIENT.asc
  • RCP130 BIEL LAST SOLUTION.pdf
Happy New Year.....
You still need a resistor in colector of the current mirror like Bob Cordell solution. I use 33K ohm in my simulation.
My most recent development...
Here I do not use resistors to try to set a fixed current in the VAS... instead I implemented a ccs that sets a fixed voltage in the bases of the VAS "helper" transistors.
It seems to provide a very stable VAS current without compromising OLG.
I am not sure if this solution is works in reality so I hope you guys can help me with your comments.
I did not have the time to include my models in the asc files so I am including those in a txt file.
I modified the circuit values to have a stiffer CCS setting VAS current and added two 150k resistors R12 and R57 so to increase it's impedance and maximize Loop Gain.
Simulations seem very good but there is surely room for optimization.
Maybe the ccs current setting resistor should be split in two with center tap grounded ... ??
I really need your input here.
See my message.
Use driver current common mode. They behave almost or as colse as i can think to the Vas current.
For your vas and driver it may bee a idea haviind a diode in they're common emitter's.
This for youre mirror transistor is getting a terrible low colektor emitter voltage. Here models fail !
