SlewMaster Builds
jwilhelm
Slewmaster sounds great with a "slam" in the bassregion I never heard in other of my builds. But there are plenty of details too.
With no signals connected it is dead silent in the loadspeakers. With a signal connected I can hear a very low hum. I must put my ears close to the loadspeaker to hear this.
Any cure?
Input is isolated from chassis. One transformer and one power unit.
Eivind S
jwilhelm
Any cure?
Eivind S
What is your IPS?
I am temted to try the "one star point method" and see whats happen. To this one point I will lead zero (one of course) from Slewmaster PCB, zero from power bank(also only one) and the minus(-) from loadspeaker terminal. Same will be done from the other channel. Have anyone tried this?
Think I will try this before your "method", yngvejos.
By the way, the hum level depends on what is connected. Different CD player connected result in different hum levels(!?)
thimios: Is other IPS better when it comes to the risk of hum?
Eivind S
If the hum is only happening when two inputs are connected, it is likely caused by excessive current flow through the signal grounds. One cheat we used to do in car audio was to leave one ground shield in the RCA cables connecting the amp to the source open (disconnected). It's not a perfect fix, but the loop is removed and both channels will share a single ground path. Another option was a signal isolation transformer. This is also not an ideal fix.
A single transformer can be used with dual rectifiers and supply reservoir capacitor banks. This takes more space, but not as much as dual transformers. This works very well.
Hum in Slewmaster
jwilhelm: The "car" method: Yes, I now about this way to fix a hum loop. I have used it with good results before, but wih my Slewmaster it did not work. The hum went loader!!
Dual rectifiers could be a solution, but then I have to rebuild the reservoir capacitor bank. As you can see from the picture, that will be some job and I also have to buy a new "bank".
jwilhelm
Yes, the hum is there only when stereo is connected. But double trannies and powerbank; there is no room for that.
Eivind S
ReadD.Joffe and implement his HBRR + HBRL.
What meausrement do you get for output Hum + Noise on the 199.9mVac sacle of your DMM? I suspect you have between 0.3mVac to 1mVac of H+N at output when stereo interconnects are connected and vol pot turned down to zero.
Do you have 0.0mVac when the two inputs are shorted?
That's a nice big bank of capacitors. No problems with instantaneous current delivery. You only need connect the ground busses at the end of the run.
My slew masters are all mono blocks so sorry no help from me. I did try a stereo version on the bench with a single supply and had a similar problem to you. One input hooked up was OK but if both were hooked up there was hum. I never solved it.
