Tweeter part
Something like this then:
Membrane is not so deep and moved closer to the front pole piece.
Yes, definitely stronger flux.
I hope I can mount it .
Nice flux in the gap,and very linear
Yes, 30 % increase of the flux density is not bad.
Thank you, Bernt!
Finally got my 3D-printer, Prusa i3 Mk3, a couple of days before christmas:
It took 1 hour and 53 minutes to print 2 cm of one side of SLAM!.
So the building rate is 0,5 cm an hour.
ABS filament at 0,2 mm height and 20 % fill.
I guess it will take a couple of iterations before I am satisfied with design.
One huge advantage with this building practice is that a smooth front can be made with any diffractional edges.
But this is not the case yet.
Some iterations later:
Front:
Back, with room for the back pole pieces that will be mounted after the membrane:
As you can see prototype is armed, the magnets will be glued to the side parts in the series specimens.
And the plastics will be black; it was a little easier to evaluate the prototypes using white.
A rim has been added for the membrane holder. Usable gap is now 60 mm.
Front:
Designed the tweeter membrane:
60 mm high and 290 mm wide will with 36 pockets yield a 48x48 mm finished membrane.
The first successful cut:
6.0 Ohm, a little bit more than the calculated 4.3 Ohm. But the return feeds, the horisontal parts, were not included in that calculation.
The motors are growing centimeter by centimeter:
Weight is now a mere 12 kg, 50 cm high.
Only 30 cm to go!
The 3D printer is working 8 hours a day:
Next step is to design a folding tool in nylon.
I have tested nylon and it seems to withstand 170 degrees Celsisus, at least for 20 minutes.
Only 30 cm to go!
It didn't turn out well with the nylon plates:
But I found out that the kitchen oven "ovel shoot" when it comes to the temperature. It was actually over 240 degrees.
So I decided to build an oven out of two of these and some electronics:
Then I tried poly carbonate at 160 degrees, but that was to hot as well:
Another type of jigg:
and a lower temperature, 140 degrees, did the trick:
To fold the whole membrane in the new jigg went well as did baking it.
But the printer wasn't happy about it when I tried to make prototypes of the membrane holder:
Front:
Back:
As the holder was to be made in a softer material called TPU with a shore of 95A, didn't the extrusion gear manage to feed the extruder.
So I needed to re-build the printer. Luckily, there's a forum for that as well..
Anyway, after a week or so I managed to get a suitable membrane holder:
Front:
Back:
So in with the membrane and prepare for gluing:
Front:
Back:
Front:
Back:
Need to rethink your pic posting strategies...?
Everything (certificate, server, firewall) seems fine at my end.
Trouble shooting is ongoing...
