Sjöström Diamond Buffer group buy
Ex-Moderator R.I.P.
Joined 2005
Tinitus - I have ordered slightly too large 'lytic caps for C6 and C7 it's an awkward fit. Apologies for this, I may get correct ones in the new year. I would advise soldering C7 inside pin before R7 maybe.
Per's BOM specs says 8mm
and these are indeed 10mm
(specs on ordered cap says 8-10mm)
I hope it will still be possible
can I please ask to accurately measure distance between solder pads ends
would it be possible to 'bend it over', and solder one side first ?
Green pcb's
The last batch of the diamond buffer pcb's are green.
