For those who love SIT transistors and are ready to pay high prices for obsolete Sony parts, here is a manufacturer of SIT transistors:
Pulsed Power SiC SIT | Microsemi
Moreover, these are SiC transistors, therefore more powerful and faster than the silicon ones.
This one is a bit expensive at $2,457.5967:
0405SC-2200M | Microsemi
and you must buy 5 of them from Avnet for a total of
$12,287.9835
But one can build a beast of an amplifier with 5 of them in parallel.
One could build a similar amplifier to FirstWatt SIT-1 which would put several hundred watts as output ! 😱
$12,287.9835
This one is much more reasonably priced:
IJW120R100T1 - Infineon Technologies
It's $65 at Avnet and one only needs to buy 2.
Moreover it's 1200V part, so it can also work nicely in a hybrid tube-transistor
amplifier.
amplifier.
My mistake, the second one
is not a SIT but a power JFet.
It might still be used for audio, for example in a single ended configuration.
It's a tiny bit more complicated to use in single transistor amplifier, one might need to use negative feed-back.
With a SIT one can build a single transistor, no feed-back amplifier like this one:
FIRST WATT S1
which is the purest form of audiophile amplifier ! 😛
FIRST WATT S1
Read label before using medication
Just took a look .... Interesting device and as zm points out, the naming convention is curiously similar to the semisouth 120R100. A word of caution though - the Infineon part is adepletion mode device. So if you just sub it into a design intended for the semisouth you will get errr fireworks.....
Very interesting device indeed 🙂
Just to add,
https://en.wikipedia.org/wiki/Static_induction_transistor
The static induction transistor (SIT) invented by Watanabe and Nishizawa in 1950 http://handle.dtic.mil/100.2/ADA299605
List of, & PDF's of - "V-Fet/SIT (Power Junction Fet/Static Induction Transistor/normally-on Fet)" & "Power J-fet/SiC J-fet (Power Junction Fet/Silicon Carbide Junction Fet) / SiC Mosfet" AMPLIMOS one stage amplifiers amplificatori audio monostadio
https://en.wikipedia.org/wiki/Digital_do_MaiN
Digital Domain Product infomation�bDC Amplifier B-1d
http://www.digital-do-main.com/pdf/SIT_forAudio(English).pdf
Roadtour
6moons audio reviews: RoadTour Digital Do Main
Just to add,
Roadtour
Hi Zero D
Thanks for pdf about SIT´s 🙂
I share this nice one to Pass Labs section 😉
Kindly regards
Kindly regards
@ soundhappy
Hi, pleasure !
I've been to Montpellier = Very nice 🙂 Toured around the SOF for 2 weeks, lovely, but VERY hot 😉
Hi, pleasure !
I need some schematic with SIT transistors , I have 4 pices of SJEP 120R100 and I would like to build someting ......
Regards ,Alex
Regards ,Alex
Regards ,Alex
Sorry Alex, SJEP120R100 are enhancement SIC Jfet, SIT are depletion type.
Try any schematic in Pass Forum or you can modify any schematic with mosfet OPS.
Francesco.
What is that:
MUSES7001 | MUSES?????????????????????SiC-SBD?MUSES7001?????? | ???? | ?????(New JRC)
false promises ?
false promises ?
What is that:
false promises ?
It's just a diode
Too expensive.
I don't like paying £10 each for ALF lateral mosfets but do.
- SIT Transistors for audio ?
