SIT Transistors for audio ?
For those who love SIT transistors and are ready to pay high prices for obsolete Sony parts, here is a manufacturer of SIT transistors:
Pulsed Power SiC SIT | Microsemi
Moreover, these are SiC transistors, therefore more powerful and faster than the silicon ones.
This one is a bit expensive at $2,457.5967:
0405SC-2200M | Microsemi
and you must buy 5 of them from Avnet for a total of
$12,287.9835
But one can build a beast of an amplifier with 5 of them in parallel.
One could build a similar amplifier to FirstWatt SIT-1 which would put several hundred watts as output ! 😱
My mistake, the second one
IJW120R100T1 - Infineon Technologies
is not a SIT but a power JFet.
It might still be used for audio, for example in a single ended configuration.
It's a tiny bit more complicated to use in single transistor amplifier, one might need to use negative feed-back.
With a SIT one can build a single transistor, no feed-back amplifier like this one:
FIRST WATT S1
which is the purest form of audiophile amplifier ! 😛
Read label before using medication
Just took a look .... Interesting device and as zm points out, the naming convention is curiously similar to the semisouth 120R100. A word of caution though - the Infineon part is adepletion mode device. So if you just sub it into a design intended for the semisouth you will get errr fireworks.....
Very interesting device indeed 🙂
Just to add,
https://en.wikipedia.org/wiki/Static_induction_transistor
The static induction transistor (SIT) invented by Watanabe and Nishizawa in 1950 http://handle.dtic.mil/100.2/ADA299605
List of, & PDF's of - "V-Fet/SIT (Power Junction Fet/Static Induction Transistor/normally-on Fet)" & "Power J-fet/SiC J-fet (Power Junction Fet/Silicon Carbide Junction Fet) / SiC Mosfet" AMPLIMOS one stage amplifiers amplificatori audio monostadio
https://en.wikipedia.org/wiki/Digital_do_MaiN
Digital Domain Product infomation�bDC Amplifier B-1d
http://www.digital-do-main.com/pdf/SIT_forAudio(English).pdf
Roadtour
6moons audio reviews: RoadTour Digital Do Main
Hi Zero D
We don't have winter last season what bring the summer this year ?
Tomorrow sit diy amp projects in pipeline be play with Tokin 2SK180 or 2SK182
Greetings :sing:
