sinus live sla-1500 repair need help
Ok thanks Perry but before doing that, where i must put the black wire of my scope ?
I do that test, black wire connected to 12Vdc GND and probe to primary winding of the first transformer with scope set to dc with 5v/div "5v/div is the maximum on my scope, i haven't 10v/div" and 0.2 time/div but i can't see a square wave 😕
Are you using a 10x probe? If so, the scope will read up to 50v/div.
I don't understand the 0.2time. Is there a 2mS setting on the timebase?
You won't see the individual pulses at 2ms. You'll see an area that's brighter than the normal background color, about 2.5 divisions high (at 10v/div, 1v/div with a 10x probe) and extends across the entire display.
That's normal. This was to allow you to see if the power supply was shutting down when the power supply makes strange noises.
While you have this set up, confirm that the power supply produces this waveform just about precisely when you apply remote voltage and remains like this until about 1 second after the pop.
I do the test and without the module the amp don't start and two leds are on and the power supply do a noise of switch like on/off etc.....it's worse than before
and the voltage on the speaker terminal vary between 7vdc to 15vdc 😕
i haven't put speaker during the test ....
Could you help me Perry ?
thanks
