I am building a stereo power amplifier and plan to use a single transformer with dual secondaries.
Each power amp board will have it's onw rectifier bridges and smoothing capacitors.
As the transformer has dual independent secondaries, I am using two bridges (one for V++ and another for V--)
As it is a stereo power amp, I will have four bridges total.
My question relates to the way I am planning to connect the single power amp to feed both amp boards in parallel.
Can I simply parallel the two positive bridges and the two negative bridges in the secondaries of the TX without fear of GND loops ?
I am posting the schematic of the PSU hoping for comments on possible issues and solutions.
Why not like Elliot, half the diodes gives 1.5V higher output, the 0.3 resistor only increases the impedance and another 1,5V less.
You want a low impedance supply less distortion, more power
