simulating variovent with MJK sheets?
just a quick word of caution. If you look at the worksheets, you will see that I have specified an upper limit of 1 lb/ft^3 on the stuffing density. A curve fit is used to give stuffing acoustic properties that match my test data up to 1 lb/ft^3. I do not have data above this value and the curve fit can go through some severe swings above 1 lb/ft^3. Please examine your results carefully, the accuracy of stuffing density above 1 lb/ft^3 is questionable.
so, 1st results: impedance only partially matches the sim (peak somewhat lower in freq, but not in ohm), but accoustic measurement seem to be OK, ripple almost gone (some caution, I have some doubts on the quality of my accousic measurement). note: 20 grams of sonofil in such a small tube is really a lot, it's almost completely blocked
will continue later with some experiments on the vent, 1st attempt will be simply halving the length...
and the sound: i'm impressed! without notch (I intend to try the one for the Cyburgs' monitor first), not broken in properly, but already nicely detailed high and amazing bass.. I had not expected a box with an f3 of ~100Hz to sound this large
