Simplistic NJFET RIAA
You can experiment with 15.1nF but it will increase highs and tighten the bass even more.
I would Let it settle for a while... Bass is still there but more detailed.
Did you decouple the psu lines just before the shunts ?
I used 1000uF Nichicon there and it gave the needed "woomph" I was missing when I reduced the 15.7nF cap.
Nichicon (the BIG can ones) are bass heavy.
Are these:
Hola Felipe,
Ami no me gusta los BG ! Cuestan mucho y los panasonics FM suenan mejor y cuestan menos.
I'm not a fan of BG's they are OK but I cost a lot and Panasonic FM's are to my ears the best. To bad they don't have all values and voltages I need ;(
Best regards,
Audiofanatic 😉
Hi/Hola Jose
Pana FM only arrives till 50V & I need minimum 63V because voltage after reg is 55V
Every cap has it´s signature... they all sound differently depending on the listener and the system used.
IMO the Nichicon are better for this case because of it´s bass lift.
Do you have a very good combo: mains cap filter 10.000 or 15.000 Jensen 4 pole works very well in highs & Nichicon 2.200uF 100V Gold Tune works very well in lows😉 (I know because I have 8 caps 10.000 Gold Tune in my Borbely balanced preamp)
