You have an oscilloscope, don't you? Read some online general guidelines on oscope by googling ''how to use an oscilloscope'' like that, and tweak some knobs until you see the 300Hz sinewave from track 5 on its screen Then you can compare for height between outputs. Opportunity to learn something useful.
http://www.youtube.com/watch?v=zQDuZ3a6HAE
YouTube - Basic signal measurements using an oscilloscope
Well I'm see a square wave using the scope.
Newbie question about Power transformer? I have been reading the pdf file that PSGR produced about the transformer required for a MM Cartridge. I have a shure m 97x, so I need the 24V 50VA transformer. Can I use the Hammond 166L24 which is a 24v 48VA transformer? It is cheaper from digikey than a 24v 50va toroidal transformer. Any input is appreciated. Thanks
The split bobbins are better for primary to secondary leakage capacitance. Such a scheme has some benefits of the R-Core but the right angle corners don't make it magnetically silent. I don't think that an electrostatic screen would not help as stated. Better than a toroid in my opinion, but will still need a separate or large box. PSGR, how is it going? We must collect some later stuff like schematic of the low MC and substitute the fixed regs with a universal V1.0 like Merlin's with trimmer and remote sensing for all voltages in a pdf sum up revision at a point, what do you think?
Ricardo, today arrived mine Obbligato's Premium 3.3uF 630VDC, wich is both legs is the outer foil? how time is aprox. the break-in?
Only for fun, Obbligato's in Salas Low MC Phono RIAA photo:
- Analogue Source
- Simplistic NJFET RIAA
