I would think that you would lose one of the major advatages of SMD, shrt traces and small layout area. I have my SMD version in a 2.5 x 3.8" area with all cap included. It's kinda fun🙂 I really like the idea of the SSLV being on same board. Very professional looking. Second set I may try adding this plus dcb1 to output. This stuff is like play time for me😀
Bros. My TT is not worthy. Plus, gotta finish my speaks to really enjoy.It's on the list now. I was always content with cd/flac, but my high res version just doesn't sound then same. Of course we have different setups. I am bringing it home tonight to see if I can check curve and distortion successfully. Been looking at SMD RiAa layouts. Is it best to have ground plane encompassing opposite side of majority of traces? It's such a big topic, hard to know where to start. Any penalty in adding SSlV on same board like you suggested? His old pre had RIAA in a enclosure inside the main case. I assume for further noise isolation.
Major heat sources should be away from the gain Jfets, especially input stage. Ground plain can be ill defined paths if used for general grounding, better be just a guard.
Yesterday I visited a friend that uses a 4w triode amp from Swissonor.ch feeding open baffles with single full range drivers from PHY-HP.
We hooked the folded to his Thorens 124 with SME3009 and DL103... waited 30 min and wow.... incredible detail, super wide soundstage, no noise, super dynamics.
Totally obliterated his Beard phono.
Yes... his setup brought up the best in the folded.... subtle inner detail, poise and dynamics.... Never heard anything like this.
Full range drivers complement Salas stuff well. They have a nakedness to their presentation of the music that is hard to match with multiaays. I enjoy minimal circuits that perform well. The more complicated a design gets, the harder it seems to get it just right. Not to say it t can't and isn't done, just difficult. Brothers speakers are Mark Audio Alpair 10.2. Über lightweight metal cone that is simply a pleasure to listen to.
ANother session today. We will be switching the output caps to Mundorf SIO from the current Obbligato oilers. Question. Is there a limit on the size of the coupling cap between first and second stage? Doesnt it just set LF pole.
0.047uF is the interstage in FS-NJFETRIAA. Only reason to go up to 0.1uF is if having suboptimal output capacitor value regarding the Zi it couples to. Yes, it messes with the tailored infrasonic response and that is audible in combination with speaker size, room, and TT. Don't experiment with value if possible.
One last bothersome question. CAn you think of an idea where something could be incorporated into a board to allow for easy cap changes. I thought about copper standoffs, allowing one to screw done the leads, but I am unsure if this will have a negative impact on the performance. I cannot think of any kind of connector that would be easy for this sort of thing. Long leads would seem to be problematic and leaving adequate space on the boards also seems to be problematic. Some of the Russian caps are quite large and I am unsre how to organize this thing to be clean, neat, and low noise.
Buzz, check item 261150895343 on ebay. Those 0.047uF FT-2 teflon caps are quite compact (31 mm long, 20 mm dia) compared to the usual ones.Some of the Russian caps are quite large
Its the only one I didn't order. I have both Ft3 and Ft1 coming. K75(bypassed with Ft1) for the output.
- Analogue Source
- Simplistic NJFET RIAA
