As they should be!
I just came across a static bag with matched FETs I. Ought from you over 10 years ago.
Nick,
How much VAC can the reg accept? For example, the Type 80 rectifier allows about 15VAC through at 350VAC applied to the anode.
Greg
The reg does not have a rectification section of its own. Its DC input. Accepting from 120V DC up to 400V DC.
Hi All
Reaching out for some assistance.
I've built 2 x SSHV2 Regulators using the GB PCB which will be partnered with the TubeCad PH2 Phono preamp
Each channel of the preamp draws about 10ma, the target B+ is 300V.
The power supply filtering on board the PH2 PCB is RC RC: 1.5K 50uF 1K 50uf. The caps are PP
Both channels of the preamp are working perfectly via the raw DC supply and each channel pulls about 10ma.
The signal ground is common between the 2 channels.
I've separated the B+ supplies to each channel
The regs work beautifully on the bench with a 27K Dummy load resistor and an input of 350V.
The target current is set to 30mA (300mV) and is rock solid and the B+ varies by less than 1%
Heat sinking is more than adequate, after 1/2 hour they are barely warm to the touch.
The problem comes when I connect to the PH2 Preamp.
When I connect the reg to the PH2, I am using a variac to wind up the voltage. When the incoming DC has reached ~150V things are looking OK.
- The LED is lit
- You can measure 300mV at the test point.
As I wind the voltage further up, the IRF840's go "pop"
I've burned out 6 under experimentation and following the failure, a resistance measurement between the Drain & Source pins measures in the range of 2 - 5K ohms.
It seems to be a very repeatable mode of failure.
In each instance, I've always pre-confirmed that IRF840s are insulated from the heat sinks before power up.
I'm at a loss to explain this, but am thinking the issue may pertain to the fact that at the point of failure, the DC heaters may not be fully warmed up - therefore the tubes are not pulling any load.
Or otherwise, the PH2 filter Capacitance (100uF) is too large and is causing inrush.
The S0 & F0 and S+ & F+ pairs are twisted and connected to the PH-2 + & - input terminals. The run is ~ 20cm.
When not connected to the reg - you can measure that each pair are joined at the PH2 PCB
I've use this wiring to the raw DC so am confident there are no issues here
I'd really appreciate some support on this - as I'm out of ideas.
Cheers - Reuben
- The LED is lit
Cheers - Reuben
Hi
Surely no small components are broken too? Please inspect. Inrush at the load should be limited by the CCS anyway. Let it come up instantly without the Variac. Maybe a long time stress develops between what the shunt voltage Vref tries to achieve and what is meanwhile available.
Thanks Salas
What you are saying makes sense. Parts are on order, but I now face a COVID patience challenge waiting for them to arrive
Wishing you best of luck. See about using it in two output wires mode too. By connecting force and sense locally at the output connector. Just in case there's something weird going on with the channels common ground referencing. Let me know when ready for new tests.
Hello.
Is it possible to use the 2SC2240BL transistor instead of the 2SK117GR, of course remembering about a different pin arrangement.
Piotr
http://raylectronics.nl/pdfs/2SC2240_TOS.pdf
Piotr
No, that is a bipolar transistor! Not a JFET. You may use 2SK209-GR(TE85L,F) surface mount current production Toshiba JFET on SOT-23 adapter board to through hole. Its the same as a 2SK117GR inside.
Surely can go lower Vout with smaller value voltage reference resistors (R9, R10). That one is easy. But to provide 1A there must be found Depletion Mosfets (Q1 Q2) of such current ability (enough IDSS). Maybe there are some available with at least 150V spec also? I don't know.
I guess this is more suitable 500V 1.6A TO220 IXTP1R6N50D2
Rgds on 2.3 ohms
Vgs off -4V
Rgds on 2.3 ohms
Vgs off -4V
Salas how I split the B+ after the SSHV2 using RC: What's better high or low C value after the SSHV2?
- Power Supplies
- Simplistic mosFET HV Shunt Regs
