Oliver, there is only one Zobel cap...
PS. Do you recognize your board?
Sure i do Looks cool with the red JENTZEN caps.
I still have the Mundorf M-Caps on my personal boards. Perhaps i try a M-Cap supreme....
BTW, i've got some 1K0 bulk-foil trimmer from Texas Components. Let's see if it perform better as the standard...
The board I was using apparently was based on this schematic...
Yes, that's the one linked from post #1 as the evolved one. Some use clamping diodes on the gates as I have shown also, some don't, but there is no appreciable failure rate reported here with either.
Now the 1260W 1K0 Bulk Metal Foil Trimmer ($29.29 from Texas Components) is installed.
Very interesting... The bass goes deeper and is more precise than with the standard trimmer.
For source information about the Bulk Metal Foil Trimmers, look into my Blog.
Additionally the 1µF of the Zobel is bypassed with a 0,047µF/500V russain K72P-6 teflon cap.
I have also changed the heatsinks to a bigger one, to have a bit more "Air" for shunting
The result astonishes me! I think that´s the last tweak on my SSHV modules.
Now it´s really time to design the case for the whole DAC.
Oliver your 1260W +-10ppm TCR trimmer is 10% or 5% tol.? Actually I use 1280G 10% 15ppm. I asked Texas Instruments price for Vishay 1285G 1K trimmer +-5% tol. +-5ppm TCR, 1260W at 29$90 USD sounds high priced considering 1280G cost 12$50 USD if you buy from Michael Percy Audio.
My trimmer is a +-5% tol. one.
Why don't you just measure the final set value and then put a good same value resistor in its place?
Also a possibility, but i want to be flexible for different tubes and
to check different tube rectifier!
That's a good idea if regulator it's only for an application, fixed resistor can give exact value as a trimmer except if you buy a "on request value" naked Vishay....
That seems to be the best approach sonic wise - and the most economic one.
Jeez, Joshua, where did you get that from - 1uF/600V is a standard value and readily available on fleabay.
The Obbligatos are a okay too, but physically big and that metal case can be a pain.
The Jantzen's are more "toppy" but still rather okay in comparison to the inexpensive little ol' "Audiophilers" - IMO, I might add!
... my 2 cents.
... my 2 cents.
Oliver,
Try the Sonicaps instead of those Mundorf "Audiophiler" MKPs, with/without the K72s.
Perhaps i go with 1µF Mundorf Supreme...and bypassed with 0,1µF Duelund VSF DC Copper
Oliver do you hear better or worse sound changing adjust current resistor?
I didn´t try this. My value is still 56R with a PRP resistor.
Try Mills, Welwyn or Vishay/SFernice (vitreous enameled) & let us know?I didn´t try this. My value is still 56R with a PRP resistor.
I use Auricap bypassed with FT-3.
- Power Supplies
- Simplistic MosFET HV Shunt Regs
