Simplistic mosFET HV Shunt Regs
Depends on what ailment that CCS was mainly fixing in a design. If its basically for PSRR and not for problems with stability of bias or to absolutely achieve a certain voltage gain, then a cleaner and already CCS blocked B+ can be a good reason to re-evaluate a proper value plate resistor in its place. That will change the load line from horizontal to slant and remove any intrinsic hiss from that CCS element if it was detectable. It will come out different. In other words, experiment and evaluate.
Thanks! This makes a lot of sense. I like the idea of trying a plate resistor.
One more question, can you give a guideline of minimum capacitance needed before the regulator? I will have a CLC in a separate box with something like 10uF 15H 47uF. I simply don't have room in the amp chassis for much capacitance. I was wondering if I could get away with say a small series resistor in the second chassis and then 1uF right near the regulator input (another RC essentially)? I realize you have advocated many times to avoid this configuration but in this case it will be my best option, if I can keep the regulator performance up.
1uF wouldn't be effective at ripple frequencies unless the R would be impractically big value eating out too much voltage. But it would still be a welcome cell for rectification's EMI attenuation and umbilical decouple. Practically try your prefilter config to measure no more than 500mV RMS ripple at the reg's input. Can't you use say 47uF electrolytic instead after some small R there? Still not that bulky.
luvdunhill: Why not add a 220uF electrolytic after the choke? that would improve things alot. I don't know why so many people here are afraid of electrolytics in PSU. At least to my findings there isn't pretty much any difference at all sound wise- if bypassing them with film caps.
And i also take the first 10uF that you have a tube rectifier? otherwise there is no need to use such small value.
