Simplistic mosFET HV Shunt Regs
Hi guys,
I built the HV pcb Kit from you. It sounds amazing, however mine only ran for a short while.
I am running it at 300V output and 50mA.
It seems that my heatsink was not up to the job and I overheated the transistor - I measured 75-80 Deg on the sink a few minutes before it went silent.
I only get 85V output now, so that's gone.
Ordered a replacement transistor and a large heatsink. However, do you suspect other parts might have gone in this except the transistor? I would like to order all the replacements so I can get it all done at once.
What is the temperature the heatsink should stabilise at?
Thank you and congrats on the design and kit.
Andrei
There is a big chance that some other semis went south. The fastest method I use now is to take them all off and measure them, even if it doesn' t seem it is.
You are going to waist more time if you just change one and then it doesn' t work again. There is also a chance that you burn some more on the process, so I say take all of them off.
Also make sure that you have enough heatsinking. Remember that sinks inside cases are not so effective.
