Hi.
I need to buy an inexpensive oscilloscope to measure the output signal/voltage from my turntable cartridge from each channel so I can set Azimuth and be sure that the left and right channel are outputting the same level.
I know nothing about these things but I see prices betwen 40 bucks to thousands. Can I get away with a cheap one for this purpose?
https://www.amazon.com/HANMATEK-HO1...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Thanks,
Stu
Thanks,
Stu
Hi Stu
I would look for a 2 channel scope. By inverting a channel and sum you can see the true balance.
Cool, maybe something like this?
https://www.amazon.com/FNIRSI-Oscil...-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
After verifying your phono preamp channel gains are matched, just use the RIAA outputs and your DVM.
The setting of your volume control could also affect the channel balance.
Rayma but I want to set the Azimuth angle in the cartridge, I'm not trying to match channel gains on my phono pre-amp there are none.
No, you first just verify that the phono preamp gains are matched between channels, and then use it normally and measure the outputs. Measuring a few mV directly from the cartridge is not trivial. The phono stage outputs will be 50x to 100x larger at 1kHz
than the inputs.
than the inputs.
When I do this I typically measure from the output of the phono cable with the preamp not even connected.
- Design & Build
- Equipment & Tools
- Simple Oscilloscope Question
