Hi.
I need to buy an inexpensive oscilloscope to measure the output signal/voltage from my turntable cartridge from each channel so I can set Azimuth and be sure that the left and right channel are outputting the same level.
I know nothing about these things but I see prices betwen 40 bucks to thousands. Can I get away with a cheap one for this purpose?
https://www.amazon.com/HANMATEK-HO1...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Thanks,
Stu
Thanks,
Stu
Hi Stu
I would look for a 2 channel scope. By inverting a channel and sum you can see the true balance.
Cool, maybe something like this?
https://www.amazon.com/FNIRSI-Oscil...-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
After verifying your phono preamp channel gains are matched, just use the RIAA outputs and your DVM.
The setting of your volume control could also affect the channel balance.
Rayma but I want to set the Azimuth angle in the cartridge, I'm not trying to match channel gains on my phono pre-amp there are none.
No, you first just verify that the phono preamp gains are matched between channels, and then use it normally and measure the outputs. Measuring a few mV directly from the cartridge is not trivial. The phono stage outputs will be 50x to 100x larger at 1kHz
than the inputs.
than the inputs.
When I do this I typically measure from the output of the phono cable with the preamp not even connected.
A scope without good bandwidth limiting simply isn't suitable, 100MHz of noise is 100 times the amplitude of 10kHz worth of noise, all else being equal.
Checking azimuth requires a test disc with separate left and right channel tracks, tune for minimum crosstalk, don't expect better than -40dB crosstalk from vinyl, but the ear doesn't really care below -30dB anyway.
Measure after the phono preamp or you might be injecting more signal than you measure!
Equalizing the output levels involves having some gain/balance adjusting circuit - the balance control on an integrated amp for instance.
Azimuth is about keeping left and right separate, not matching levels.
- Design & Build
- Equipment & Tools
- Simple Oscilloscope Question
