Hello,
Has anyone seen a simple on/off relay circuit for an SMPS without soft start?
I would like to have a low voltage Anti Vandal type momentary type switch that when pushed in for a few seconds lights up and turns the amp on and then when pushed again for a few seconds goes off and turns the amp off.
Anyone seen such a circuit?
Preferably a board I can just buy.
Looking around the webs, I didn't find anything suitable.
Thank you,
David.
Thank you,
David.
You are describing a "Latch"...a logic switch, whereby a momentary initial application of power feeds back upon itself & keeps the switch "on".
-------------------------------------------------------------------------Rick............
Maybe it's worth twenty minutes of your time to look at a full and complete circuit design that has worked for a large number of diyAudio members
PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXG
and then ask yourself: when I delete all of the "soft start" circuitry, am I happy with what remains?
This does what you want, but there is no delay. It's instant on off.
12V Bond Bistable Relay Car Modification Switch Start Stop Self-Locking Module K | eBay
Maybe you can hack it?
I used this one in my Aleph J build several years back.
The ε24 power switch driver circuit
I used the separate transformer board, as well.
The easiest way is probably to use a tiny microprocessor, a few lines of code is all that's needed. It could be done with 7400 series chips. Two timers and two latches, maybe some additional switch debounce circuitry as well.
i Still have spare boards left from my last build, this circuit is based on APEX on/off switch design. PM if interested.:https://www.diyaudio.com/forums/power-supplies/355530-relay-switch.html#post6230578
- Power Supplies
- Simple on/off relay circuit (no soft start) with low voltage switch?
