Lumba, I have plans for a power amp based on my experience from the folded cascode headphone amp. I'll be using JFET/bipolar CFP in the input stage and maybe cascodes as well. SK170/SK246 as CCS to the LTP. Not sure about the current mirror. I'm quite happy with the folded cascode topology, so I think I go for that. I think I'll hang on to the diamond buffer output stage but with double EF. I've tried diode biased EF, but I don't like it as much as the diamond buffer. Since I know the importance of how the speakers return currents are handled, I'd like either a BTL or fully balanced amp.Lumba Ogir said:Nelson,
I have been doing that for years. Now, how far are you prepared to go?
Very nice amp Lumba, I'll bet it sounds absolutely fantastic. What output stage do you favor? I have a hunch you've already told me but I'm sorry I've forgotten it.
Lumba, I've been reading some of your old posts. Your ideas about CFP bipolar/MOSFET output stage looks interesting. Could you please show an example of a low power amp with MOSFETs available from ELFA so I could do some experimenting.
And sorry to you others for this threadjacking.
Nelson,
Take your time to plan the topology in detail. We can discuss it later.
JFETs should always be cascoded in common source mode.I'll be using JFET/bipolar CFP in the input stage and maybe cascodes as well.
You will need at least 10mA.SK170/SK246 as CCS to the LTP.
Check out the effect of R14 in your headphone amp.Not sure about the current mirror.
No dirty ground as far as the eye can see.I'd like either a BTL or fully balanced amp.
- Shunt or serie volume control
