Should grounds go like this?
Could you please confirm that grounds should be connected like this as shown...
regards
Leander
Actually its a CFP driver stage and it isolates the driver thermal variations from the bias chain. As such drivers have a large variation in demand current supplying output transistor/load needs, it's a good idea. I used this in the Magnet 300F - which won the 'golden ear'!
Regarding grounding, the chassis should be connected to incoming power (mains) ground and circuit ground connected to it (from the star point) via a low value resistor with back to back power diodes. This helps prevent ground loops when other equipment (of unknown method) is connected.
Greg
