xr5 replacements
OK using your picture with red annotation for each xr5 there are:
Traces: [T-1] [T-2] [T-3] [T-4] [T-5]
Pads [P-1][P-2] ( XR5)
[P-3][P-4] (XR5)
Ribbon Cable
which pad goes to which trace??? Sorry to keep after this I just want to get it right!
Thanks,
Seve
[P-3][P-4] (XR5)
Ribbon Cable
Thanks,
Seve
[P-3][P-4] (XR5)
Ribbon Cable
Thanks,
Seve
No need to be sorry
I don't see solder points in blow up of image, can you specify points to solder caps. I have the old smt pads cleared but it doesn't look like the are both used????Thanks!!
Steve
You can not solder exactly on the same SMD pads. To solder new caps, I used only the ground SMD pad - if you zoom my pictures, you can see that there are two pads connected together, these are ground pads.
The other solder point is directly on PIN IC pin.
The pictures I have attached, are high resolution and you can zoom them - click on picture and then on left down corner on zoom button.
Regards,
Tibi
[P-3][P-4] (XR5)
Ribbon Cable
Thanks,
Seve
Seve,
Here you lost me ...
You want me to note each pad ?
Information related to ribbon cable is in datasheet page 8.
Regard,
Tibi
Tibi I was looking for a way to read the error flag output as a means of getting a better idea of what happens when we change stuff, but I see from the MK1 schematic that pin 49 of LC78601E is pulled up to V3.
The datasheet specifies that the pin output is available only in test mode. Any idea how this might work?
First, you need to disconnect pin 49 from 5V and connect to a scope or trough a gate to a LED.
Second, you need enter in test mode. This is possible only by adding a additional button to keypad - see LC78601 datasheet page 8 and look at keys.
Once you have activated TEST button, trough pin 49 you'll have C1 and C2 detected and you can add a counter to see how many errors a CD may have.
Regards,
Tibi
That cheap 1-turn trimmer does not even have much accuracy anyway... We should be ok within reasonable limits of accuracy.
Still I cannot pull the triggerFraidy cat...
I bypassed the trimmer with a 1nF Silver Mica.
Since I pretty much have no standard laserplatforms left I came up with a nice listening test using my two very first platforms.
One equiped with the 47nF (the looser) and one with the Vishay (the winner)
I equiped the looser with the 1nF Silver Mica (500v) for the monitor diode trimmer.
This time the "looser" became the "winner"....it seems like you gain a bit more power in the music and musicality rises a notch....I think I will leave it there
I ll be waiting on your findings.....
Is it just me or is this the smoothest and yet more textured and focused sound ?
No you are right.....I think musicality rises a notch...like velvet...
Well, I was wrong, the difference is perceptible.
It's my turn to thanks Erik for trying and testing this.
Regards,
Tibi
PS. This weekend I'm going to compare Shiga MKII against Audio Aero Capitole and Gryphon Mikado. ;-)
Here is the image that wouldn't open above. Thanks
Steve
The top cap is correct, but bottom cap must be exactly under the top, so use next pin under.
Regards,
Tibi
- Digital Source
- Shigaclone MKII Black - The builders Thread
