Okay here the problem I have decided to take the plung and build the power supply; with a astec atx200-3509 200watts.
I have got it jumped
I then plug it in, the fan turns on i wait a few sec's then i hit the on switch on the projection panel, the power light does a quick flash then goes back off, then the fans turn off and now there no power so i have to unplug the atx from the wall for about 30secs I dont know why but thats how long i have to wait for it to work again.
Can any1 post how they got theres to work, tell me what i am doing wrong, also in my picture the red goes to the 5+ and yellow to 12+, then blacks go to the grounds, I put them on different ones to see if it mattered still same i have tried almost anything I could think of.
It seems when I hit the power switch on the projection panel that it pulls so much for the power supply, that the power supply thinks it is being overloaded(Hypothesis) and there is something in it to tell it to turn off so it wont over heat or _________
Any help will be appericated plz post any post is better then none
I figured it out no that did not work. I bought a 300 watt one Aopen brand works good if anyone is having the same problem I did you should purchase a new Atx power supply seems that old one dont work too good
Mike maybe this would work for you - has 5V and 12V - I believe it may have the same connector as your panel. Hope this helps😀
Power Supply
Power Supply
