Thanks for your review. Btw the nxv300 link did not work but gave a 403 error. Thanks again --- Per
Try it again 😉
wow great review. can't wait til mine arrives. sadly shipping was delayed for mine a few days
Thx you Oliver . We take full responsibility for making you change the speakers 🙂
A few more words. I also found that Rev has the best bass . I believe this is the direct results of using the supercaps on analong rail of DAC (2 farad around) + supercap on analog rail of opamp (that was never tried before). The result is bass like I never experienced . No math (like bass boosting) just power rails that do not sag when hitting low notes.
...just power rails that do not sag when hitting low notes.
I know what you mean. AVCC and to a bit lesser extent opamp rails. Question for you though: Do you see the effect in measured frequency response? is it visibly improved?
I don't think it would show up in frequency response measurements.
Hi @cdsgames
When ordering the Allo triple play: USBridge <>Shanti<>Revolution
and requiring WiFi from a NAS to stereo system in a different room, which modem/dongle from the Allo web site for the USBridge? My router supports both 2.4 GHz and 5 GHz
What do you recommend #1. or #2.
#1. USB WiFi Dongle
#2. Dual Band USB 3.0 WiFi Dongle
Lastly, regarding Revolution drivers, if all I require is NAS WiFi do I require a driver?
I do NOT require DSD 512. I am using Volumio.
#1. None
#2. Xmos ID / Win (native driver)
Thanks in advance for answering those two questions. (ツ)
#1. USB WiFi Dongle
#1. None
Works now. Thanks. Serious build 👍
Holton Precision Audio amp. These sound amazing!
Be interesting to hear your thoughts on this. Received mine today - using it with Shanti/USB Sig and it's replaced a Kali/Piano 2.1. Had it warming up all day and just started listening. Initial impression are very good 🙂
I prefer for the moment to keep it private not wanting to influence what users find . I encourage trying different settings. Tweak it and tell us what you like best.
@cdsgames
When using the USBridge Sig with both a USB DAC and a USB hard drive, would you recommend connecting both to the 'Clean' USB port via a hub, or connecting the hard drive to one of the wifi ports?
Generally speaking I would not connect anything noisy to USBridge
Harddrives are better mounted on network (another RPI) , however if you still want to use it on USbridge I would think that a USB powerd hub is a better option
Cdsgames, as far as I remember, you also did what you could to isolate / filter the ethernet port, right?
That's fair enough, I'll have a play when time permits - too busy listening when I have chance at the moment 🙂
@cdsgames Is there a US/Canadian distributor for the Rev and Nirvana? Chicago Electronic Distributors doesn't show it on their website and they didn't respond to my query on FB.
I have change my cable in the afternoon.
From my Usbridge Signature, to my revolution.
From the Flex cable to the Tellurium Q Black USB ☀️
So what a difference, easy podium, you can taste musican podium
my Allo Revolution dac arrived here in hawaii but I can't find the DC cable that goes with my nice 5V Jay's Audio linear power supply. New cable arrives sunday. I spent all night searching for the cable, flipped all my cable drawers upside down on my bed. I had to sleep in the other room LOL
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
