Nirvana first pics , running for the past 7 days at full load (2.9A) with 110 and 220V
Temp of alu casing 42C with 24.5 ambient
Do you have measurements of the noise on the output? You mentioned previously that with the transformer modification(s) that noise had increased, is that a significant increase, and is it still better than the iFi iPower.
Hi everyone,
Im currently using the usbridge sig with digione sig and i like how it sounds... i have a project where i want to use the usbridge sig with the d3 tda1541 dac.. my questions are
1. Will the usbridge benefit from reclocking using ians fifopi to output i2s into d3 dac or
2. Is it better to use usb output of usbridge going into waveio then output i2s into d3 dac
Reason im asking is that, i compared the usbridge sig with digione sig spdif output straight to my dac against spdif output going into ians fifo reclocker then to my dac and i like the sound better of the digione sig output straight to my dac.. im using crystec clocks on ians fifo reclocker..
It seems that the reclocker took away the life of the music.. i have to force myself to get involved in the music, however with the digione output, i just get involved with the music.
Anyone has the same observation?
Yes , we will offer it , starting this week .
There is one guy on AS forum who reported that DSD via UPnP did not work with RopieeeXL.
Maybe there is a problem with the ASIX driver?
Can you check with Harry?
Matt
Edit: The new review on AS reported SQ issues with Ropieee too.
Hi everyone,
Digione Sig already has output recloaked right before outputting stream using buffers . Instead of Crystek we are using NDK SDA oscilators (ultra low jitter)
USb vs Spidif vs i2s. Frankly before thinking about advantages and disadvantages of each bus , I think the most important thing is how the inputs were designed in the DAC. Simply put the best input depends on DAC hardware implementation . If all inputs are perfectly implemented , I would chose i2s (Master mode NOT slave)
As such there is not one answer.
Matt
We have tested Ropiee extensively and it works very well. Please note that Dacs need to be native DSD on Linux and both weren't ..
Excellent review of USbridge Sig
Allo USBridge Sig Review - Reviews - Audiophile Style
Note that he found that optical module is not helping much with USBridge Sig (yeap we cleaned the common mode noise)...but I have it from a person I trust the opinion that EtherRegen is working great (good bump in SQ) with USbridge Sig.
Must be that those clean (reclocked ) ethernet packets play nice with Ethernet IC...but I have no tech explanation for it.
You mean both Ropieee(with Roon) and RopieeeXL(with UPnP)?
Matt
Hmm , I will have to check with testing team , I know it has been tested but I don't know the full details.
But DSD with this DAC worked with Moode and Volumio.......
Matt
Yeap correct , there must be something else..I will ping Harry
As you announced on AS best solution is ALLO official version for USBridge based on Moode.
When it is ready?
Matt
Hi Matt
I dont have further details , but I am working behind the scenes to secure support from Qobuz Tidal ... and more
In fact I have been working on it for quite a while and should have some tangible soon (support from streaming companies )
It would be great if you could get Amazon Music HD support. There doesn't seem to be a simple way to get that to work with a normal stereo.
Matt
I briefly spoke to Harry , its on his " to do " list.
One more word about software , at this point I have been working for the last 2-3 months on getting approval from streaming companies to be able to use private keys ( I will not make public the whole list since some of our competitors are watching this thread, I would rather surprise them )
Once we get all approvals (basic one we got already) we will see best way to implement .
Hi
small updates.
Revolution Dac is getting along quite nicely , screen is working without any errors (i2c)
Next week , we will get the last PCB revision and then we can enter mass production...I expect it to start (mass production) in Dec end
We are also trying to implement H2 and H3 control...basically you will be able to increase/decrease those harmonics for a nice euphonics control of your DAC . Seems that controlling those H open up the sound (but are detrimental of course to the THD, still we think its nice to play with them)
Nirvana , has been under full load for almost 2 weeks. Temp is very stable , between 40 and 44C in a rather warm environment . We are trying to make a bundle with Revolution Dac
At 0.5A (rev dac) we are observing noise thats around 0.2uV and alu case is at room temp (+ 2 to 4C)
small updates.
Have you thought about measuring Transient Intermodulation Distortion, I'm unsure if DACs do have this problem though but it wouldn't hurt to measure this anyway, looking around a little i see it can be done by using a low pass filtered square wave and a sine wave.
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
