Shanling scd-t200c circuit diagrams wanted
Have in front of me a shanling scd-t200c.
Appears to be a power supply fault, no display and no transport action at all.
Tubes and two blue led's on the front (cd/sacd) glow.
Would really love the diagram of the power supply.
Or some voltage readings on the connectors for the supply section.
That is unless someone has knowledge of what may be wrong.
Save me the time of testing each and all reg.....
Almost exactly what this one is doing.
Same fault except this one has no transport action at all.
It ain't the power supply.
I have managed to find out though how to fix it.
Take it back to an authorised dealer for a wrnty board swap.
The controller board in the seperated sheilded section is known to have issues.
Shanling are swapping them under wrnty.
I would still love a copy of the service manual/schematic though.
Thanks.........
Let me know when ready to email it, I'll sent up a temp account to receive it.
Vickers hifi very likely that the problem is in the flat cable of the laser, in my SCD-T200C I had to replace it and then reads everything. 😛
Look at this ...
AWM 20798 RIBBON FLEX CABLE same side 0.50 mm pitch 26 PIN 150mm 26PIN 15cm | eBay
Does this fix the " intermittent no display no function blues lights ok " problem ? or is that fault due to the aforementioned controller board.
Had this problem for some time now and couldn't get any information, hope someone can help.
Are any had receive diagram for T-200C! Have the same problem:" intermittent no display no function two blue lights ok " Needs any help,experience, diagrams. As I see through this discussion, it is most common problem for Shanling
Thanks, Olek
It seems, that problem was in SACD controller board. Had contact with Shanling and they inform me that: "The essential ICs on the SACD pcb. has no more production and sorry that we can not sell you the controller board" .
May be there will be any ideas how to fix!
